Results 1 to 10 of 28
Thread: Electric folding wing mirrors and self dimming rear view mirror - Help please
    Mar 2013
    Castleford
    Vehicle : 1.9 TDi SRi
    Engine : 150bhp diesel
    Mileage : 65000
    Default Electric folding wing mirrors and self dimming rear view mirror - Help please
    Hi
    I have a vec 08plate sri and I am thinking of these two mods but questions are....
    Auto dimming mirror
    Is the wiring harness already there and will it just need pluging in or will |I need to add any special wiring loom
    Folding wing mirrors
    Are there vauxhall ones or after market bits
    Again is there any loom additions needed
    Are they also heated mirrors
    AND
    Should mine be heated in an sri spec of this year - pretty sure mine arn't!!
    Thanks in advance
    Shaun
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    Doubtful if the loom is already there for the dimming mirror, but its just plug and play.
    Yes VX Folding mirrors, a set just sold in the parts section for £200
    Yes mirrors are heated, press the rear demister switch to operate them.
    Mar 2013
    Castleford
    Mileage : 65000
    Quote Originally Posted by Das View Post
    When you say plug and play for the dimming mirror does that means it needs a small wiring loom that will just plug in to the existing loom, if so where does it go to, one end to the mirror but where does the other end go to
    With regards to the folding mirrors if you get the full kit what do you have to replace and does it all plug in to the existing loom.
    And i suppose the important question is after each of those have been fitted do they need programming in to the car as well
    Shaun
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 85000
    Other end plugs into the rear fuse box. There is a how2.
    You need to replace the door loom, the door modules and the door mirrors, then it all needs activating via Tech2.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    39 Post(s)
    Engine : 1.9 DTH
    Normally u don't need to replace door loom.....
    set that got sold on for sale section was out from half can car so modules won't have comfort closing folding , they will fold using switch not remote key.
    Mar 2013
    Castleford
    Mileage : 65000
    I presume the dimming mirror doesnt need activating though
    39 Post(s)
    Engine : 1.9 DTH
    Quote Originally Posted by Shajennat View Post
    It does in REC so when u open the door or select reverse then undimms
    Mar 2013
    Castleford
    Mileage : 65000
    Quote Originally Posted by Sebastian View Post
    Sorry i am thicker than i thought as i dont understand what you mean and i am doubting what a dimming mirror actually does, could you explain please.
    The programming to the car would be a problem as i dont have the code required
    39 Post(s)
    Engine : 1.9 DTH
    Driving at night time , there is car behind u with lights on , rear view mirror dimms so u don't get blinded by headlights ...
    Mar 2013
    Castleford
    Mileage : 65000
    That bit i understand it was the other bit the door opening bit and what was meant by Rec?
  1. dimming rear view mirror
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2014, 18:54
  2. Electric folding wing mirrors
    By tom_p_2000 in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 23:53
  3. Auto dimming Wing Mirror or Mirrors?
    By Craig Rogers in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2008, 12:30
  4. electric folding wing mirrors.....
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2007, 10:59
vectra jn jp ident module www.vectra-c.com
vectra c auto rear view memory mirror
