Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: CD30 TID display change to BID display, help please :)
    Regular Member Jow20's Avatar
    Sep 2010
    Leeds
    Default CD30 TID display change to BID display, help please :)
    Looking to get rid of the awful little display with the 2 buttons!
    my car is 05 full canbus preface, so just a few questions.
    1) is it plug and play to fit a cd30 from a 2007 SRI? No tech2 etc aslong as screen and unit is from same car..
    2) will the display fit my vents just like a factory look??
    Many thanks guys
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    yes
    Sep 2010
    Leeds
    What paul?? It will fit and work fine? Is yours for sale blue? Do you fancy doing a full conversion for me to match! Lol
    Sep 2010
    Leeds
    And am i doing the right thing getting rid of the tid? Does it really look that crappy?
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    yes they look very poor lol
    Regular Member multi.123's Avatar
    Aug 2012
    liverpool
    Vehicle : vectra vxr
    Year : 08
    sorry to jump in on this post but i was just about to make the same sort of post ha anyway
    my granddad is getting rid of his sri vectra facelift and just want to know if i can just take out my TID display with the two buttons (awful thing) and take the BID display out of the sri and put it into mine without his radio or will i need to take both?
    thanks
    matt
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Try and get a photo of the plug that goes into the back of your TID, and post it up on here. It might be the completely wrong one and as such a BID, GID or CID won't plug straight in.
    If it's a small black 16 pin plug, you'll need to get a larger grey 32 pin (iirc) plug from a car equipped with a BID, GID or CID already and reconfigure yours (ie unplug the wires from your plug, and pin them into the new one), before it will plug in. If you're going to a GID or CID, you'll also have to add a couple of extra pins to double up the +12v and earth connections.
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    matt, same applies to you. If yours has a TID, the chances are that the plug might be wrong. Can you post up a photo of what you have fitted to yours so far?
    Sep 2010
    Leeds
    So basically if you take both headunit and married bid screen then it will be plug and play. Aslong as the car its going into is full canbus
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Not quite... as I say if you have a TID, you might have the wrong plug on the loom so a BID, GID or CID won't physically plug into the harness that is already there.
    You're right in that a headunit and married screen *are* plug and play, in that they'll plug in and work without T2 or whatever, but only if the plug is correct. If the plug doesn't fit - then the screen won't plug in!
    If your plug looks like this, it will need to be changed: (18 pin - I said 16 pin earlier, my error)
    Whereas if it looks like this, you will be fine: (32 pin)
    (see the size difference)
  1. For Sale: CD30 & Display
    By Telly Addict in forum Parts for sale
    Last Post: 10th September 2011, 01:10
  2. CD30 and Display
    By Neil71 in forum Parts for sale
    Last Post: 19th November 2008, 08:40
  3. CD30 and display screen
    Last Post: 4th November 2008, 17:44
astra h gid upgrade
zafira a bid
astra h display change
corsa c tid code
opel cd30 display controller
TID display BC no function
cd30 tid to cd30 gid
tid to bid astra
zafira tid
can i swap display in a vectra c
opel corsa c bid displej
vauxhall sri bid screen
tid to bid astra h
astra tid to bid
changer tid en bid zafira
tid astray h
remove astra h screen
corsa d gid upgrade
Is a large vauxhall gid display plug and play
swapping vectra astra display screens
opel 32pin display pinout
astra h tid to bid
opel astra h display setting
astra gid bid
zafira a tid
