Results 1 to 10 of 14
Thread: Auto box tiptronic weirdness
    Regular Member astradriver's Avatar
    Dec 2011
    Slovakia
    Default Auto box tiptronic weirdness
    Hi Guys,
    when I pop my automatic into manual mode and for example put it in 4 at 40 mph it will run arround 1600 rpm, when I floor it then the box raises the revs sort of like when the clutch is slipping on manual. Is this normal?
    Thanks,
    Martin
    Regular Member russ1969's Avatar
    Worthing
    The box will change down to the required gear to do what your asking it to do but will not change up for you.
    Dec 2011
    Slovakia
    hmm but it still shows 4 on the gear indicator and I don't feel it changing down it's more like it will slip the clutch on purpose for a bit and than once the car has some momentum it's back to "normal". Just for the record I have a 6-speed auto 1.9 cdti 150
    Worthing
    Yes I have the same box and I am trying to remember what my display does? Very rare I use it in manual.
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    my okd siggy used to do that aswell
    Dec 2011
    Slovakia
    I just had a look in the manual (should have done that in first place) and it says it will kick down even in manual mode, though I haven't gone past the kick down point with the pedal, I just wanted it to accelerate hard. The only reason I tried this is I want to dyno the car and the guy asked me on the phone if the box will stay in gear and won't kick down. Now it seems it won't stay in gear and I can't dyno it really?
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    if you hold it in 4 dont kickdown you can rr it i did with my old car its aloaf of rubbish
    Essex
    28 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    Mileage : 97000
    the gear will always stay in the same number in manual when you floor it
    not sure what your little deisel is like but my 2.8t will start to fly up to 70 in a matter of seconds .
    maybe the deisel not the same doing 40 in 4th might need a to knock down a gear.
    think it only goes down the gears if you are driving to slow
    Dec 2011
    Slovakia
    cool, thanks for help.
    13 Post(s)
    Quote Originally Posted by soulman View Post
    I've got the 5 speed auto in my 2.2 direct and in manual mode the gearbox kicks down when I floor it. Say it's in 5th, it will drop to 3rd on kickdown, and will also kickdown from from 4th to 2nd. Seems to drop down 2 gears but haven't tried it when in 3rd to see if it drops to 1st.
  1. Tiptronic Good or not
    By BBMadness in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2012, 01:06
  2. Weirdness
    By leeroyjenkins in forum Engine & Drivetrain
    Last Post: 28th September 2011, 19:10
  3. Help needed - Auto dim mirror & poss auto wipers
    By mark_647 in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 01:09
  4. Tiptronic
    By BigBen999 in forum Engine & Drivetrain
    Last Post: 11th May 2009, 17:03
  5. Tiptronic auto box
    By ukmayhem in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2009, 17:54
vectra tiptronic display
