Results 1 to 10 of 15
Thread: what should MAF reading be at idle & 2000 rpm? anyone know vectra c 1.8 02
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    Default what should MAF reading be at idle & 2000 rpm? anyone know vectra c 1.8 02
    hi all,
    as above trying to get it through mot with high lambda reading so checking all with obd, i have maf readings of
    742 rpm - 2 g/s
    2000 rpm - 5 g/s
    does this look about right?
    cheers
    barks
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    anyone??
    or preferably a link to correct running values/ live data to compare with?
    barks
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    HTH's, engine temp of 86-87.
    Engine Speed Mass Air Flow Sensor
    RPM V
    790 0.47
    787 0.53
    781 0.39
    793 0.59
    800 0.65
    791 0.43
    794 0.41
    794 0.43
    785 0.61
    806 1.14
    1.021 0.59
    1.069 0.94
    1.198 1.2
    1.363 1.35
    1.529 1.82
    1.710 2
    1.746 1.98
    1.560 2.08
    1.485 2.14
    1.655 2.67
    2.182 2.76
    2.468 2.69
    2.705 2.29
    2.674 1.35
    2.244 1.18
    1.629 3.06
    1.778 2.73
    2.016 2.96
    2.251 3.06
    2.472 3.25
    2.653 3.27
    2.837 3.39
    3.040 3.55
    3.222 3.69
    3.394 3.51
    3.367 1.39
    2.935 1.25
    2.268 3.43
    2.321 3.16
    2.37 3.25
    2.45 3.31
    2.538 3.27
    2.617 3.39
    2.696 3.35
    2.780 3.43
    2.855 3.43
    2.944 3.57
    3.030 3.67
    3.110 3.67
    3.2 3.73
    3.308 3.78
    3.399 3.88
    3.485 3.96
    3.578 3.94
    3.674 3.9
    3.777 3.96
    3.855 4.1
    3.952 4.02
    4.037 4.12
    4.137 4.12
    4.215 4.06
    4.304 4.18
    4.385 4.24
    4.486 4.22
    4.582 4.18
    4.678 4.2
    4.749 4.31
    4.818 4.29
    4.914 4.25
    4.992 4.39
    5.068 4.27
    5.145 4.47
    5.208 4.43
    5.291 4.33
    5.249 2.31
    4.992 1.88
    4.646 1.75
    4.065 1.88
    4.097 3.61
    4.178 4.14
    4.227 4.14
    4.297 4.24
    4.340 4.12
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Think should be around 48g/s @ idle
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    thanks both :-)
    0.4lb/min is about 2g/s i think, ive got stft around 5 and long term about 11% so now i replaced the faulty lambda and still have a high reading although very nearly right i think the car is running rich because the ecu is adding fuel as it thinks the car is running lean. must be sucking air in some where. im going to clean the maf sensor check the plugs and hunt for the air leak.
    cheers
    barks
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Use a bit of soapy water in spray bottle to check for leaks.
    or can carefully use brake/carb cleaner/propane
    can you carefully squirt carb cleaner into intake and fuel trims should start changing to negative.
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    cheers critch :-)
    unfortunatly i couldnt find a cotton bud so one of the foil strips on the maf snapped, i have soldered a wire across to the other strip, are both strips the same as one strip will now be giving both readings?
    cheers
    barks
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Ones heated an ones not i believe an measures by change in heated one.
    its best when cleaning mafs to just use carb cleaner spray an then leave to dry naturally.
    replace with genuine or OE as cheap one can an do cause problems
    Feb 2013
    Northants
    Vehicle : Vectra c
    Trim : Ls
    Engine : 1.8
    Year : 52
    cheers critch, thats no good then, lol
    ive now replaced the maf with a working second hand one, ive cleaned out the throttle body which was really gunked up and had a blocked recirculation pin hole! all back on tight, now its worse lmao
    i say worse,, the stft is now 0 which is good, but maf is now 8 g/s idle and it dosent like idle sounds like its missing, however mid and high throttle the car is quicker and smoother!
    cat dosent rattle, im going to disconnect the battery for an hour in the morning to reset ecu but its now getting boring.
    the jubilee clip wasnt great after the maf so im going to change that too,
    barks
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Check for vacuum leaks mate
  1. vectra c 1.9 cdti 150 wont rev past 2000
    By safayth1993 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th January 2013, 20:08
  2. Help - High idle (1000 rpm) and high map reading
    By roswell in forum Engine & Drivetrain
    Last Post: 5th April 2011, 21:49
  3. Replies: 4
    Last Post: 31st July 2008, 15:29
maf gs
z18xer maf sensor
what should maf sensor reading be on zafura b
maf sensor readings at idle
maf gs at idle
astra h 1.6 maf readings
what should the maf read at idle and 2500 on vectra c vvt z18xer
what should the maf sensor gs be on vectra c vvt z18xer engine
maf sensor reading with opcom
maf gs chart
what should my MAF sensor read astra
maf gs idle
maf sensor reading at idle lb vauxhall maf reading with opcom 0.4vectra b 1.8 xe air mass readingzafira b maf gsmaf value insignia vauxhall zafira 1.9 cdti maf sensor readingsmaf lbs idlez18xer mafreadings from a maf sensor vauxhall mokkamaf sensor teading idlemaf reading at idleopel z22yh maf readingsMaf reading idle
