Thread: Flip key fob problems
    Regular Member david2005's Avatar
    Feb 2013
    Cork, Ireland (Eire)
    Vehicle : Vectra C cdti
    Trim : Sri
    Engine : Z19dth
    Default Flip key fob problems
    I did a search but all it came up with is how to convert from a prefacelift key to a facelift key.
    I got two flip keys with my 2008 Vectra but both of them have problems.
    The first one is that the keyblade won't lock in or out in any position. What could this be and how can I fix it?
    Second is that the buttons on the second key won't unlock or lock the car unless you press them a dozen times each.
    Is it possible to open the keys without damaging them and fix them myself without going to a dealers?
    Thanks in advance
    Dave
    Carnoustie
    I bought these for mine as the buttons were worn, made them work and look like new
    http://www.ebay.co.uk/itm/for-Vauxha...item5ae58e9e89
    Feb 2013
    Trim : Sri
    Engine : Z19dth
    Quote Originally Posted by ronnie63 View Post
    Do they come with the micro switches or are you saying its the rubber that stops it working properly?
    Can you split the fob easily without damaging it?
    Thanks for the reply
    Carnoustie
    These are just the pads, and they just pull out then you will see the buttons
    13 Post(s)
    Quote Originally Posted by david2005 View Post
    They are heat welded together and you need to cut it apart.
    The link below shows how to convert a normal key to a flip one, but it also shows how to get the flip one apart.
    http://www.yellowdawg.co.uk/flipkey/Untitled-1.html
    Feb 2013
    Trim : Sri
    Engine : Z19dth
    Thanks for the link, should've read that properly
    Thanks lads
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 12th November 2019, 09:21
  2. 3 button non flip key internals fit straight into a flip key shell???
    By Jow20 in forum Electrical & ICE (including SatNav)
    Last Post: 25th November 2011, 01:44
  3. Flip Key has lost it's flip?
    By maurauth in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2010, 12:23
  4. Flip Key
    By sb1uk in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2009, 21:12
  5. flip key
    By steeb82 in forum General Chat
    Last Post: 6th February 2009, 19:21
