Results 1 to 3 of 3
Thread: Alarm fault
    Mar 2013
    liverpool
    Vehicle : '04 (54) vectra sri cdti 120
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    confused Alarm fault
    Hi, im new to the forum and just bought a 54 plate vectra sri cdti 120. I have a problem with my alarm, as when i put the ignition on the centre display shows 'check safeguard'. Also intermittantly when locking the car, the alarm will go straight off, so you have to unlock and lock again. Another problem is water is getting in to the boot and drivers footwell. I have cleaned the scuttle panel drain as it was heavily clogged but still seems to be getting wet. Any ideas greatly appreciated!
    13 Post(s)
    Best to get the fault code(s) read for the alarm - beats guesswork.
    Mar 2013
    liverpool
    Trim : sri
    Engine : z19dtl
    Mileage : 178000
    The codes for the alarm are stored in the bcm arent they?
  1. Alarm goes off randomly-have fault codes
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 29th August 2012, 12:24
  2. alarm fault findind
    By neil29 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th June 2012, 20:24
  3. Vectra SRi C alarm keeps going off code error fault
    By Tapie in forum Vectra C / Signum Troubleshooting
    Last Post: 8th September 2011, 20:53
  4. Replies: 15
    Last Post: 9th July 2011, 22:19
  5. Fault code - alarm
    By zafira in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2011, 13:07
