Thread: Fuel filter leaking
    Aug 2012
    Stockton-on-Tees
    Default Fuel filter leaking
    Basically when I've been changing the fuel filter it's been a pain in the arse. What should of been easy has been annoying.
    Couldn't get it out the cage at all. So I undone the lid with the screw driver method which I didn't like to do but I had no choice really since I couldn't get it out. Changed the filter and the seal with a new one and it didn't leak at first but then it started to leak later on that day.
    Tightened the cap up a bit more using the same method and its slowed down to a seep now but still leaking from the lid.
    Any suggestions on getting it out and if its over tightened will it also leak? I kno it's only meant to be 30nm which is hardly anything really.
    Tighter maybe?
    wirral
    60 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Change o ring
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    What u do need to do is remove it out of the cage and properly tighten it. It have bar pressure recommendation marked on the lid. I tightened it by hand using dry cotton cloth which helps grip and tighten more than ur palm allows.
    It applies similar to recommended bar. So u'll need to get it out. Do it from underneath and really wriggle it side by side as well as pushing it up. it will soon give.
    There is a plug at bottom so careful u dont yak it out until its unplugged.
    Good luck ;-) (done this 6 times to 5 different vectra)
    Aug 2012
    Stockton-on-Tees
    O ring was replaced when I fitted it. Came as part of the kit. Forgot to mention that part.
    Ill try and remove the cage if I can. It's so tight. I thought it might of been clipped in in some way as the Haynes manual says to use a screw driver down the right hand side to release the clip but I obviously couldn't find one.
    Its 30NM that it needs to be torqued too. That's what it says on the lid.
    Thanks for the advise though. I will give the wriggling a go now I know it's not clipped in.
    Regular Member shane31's Avatar
    Sep 2011
    Staffordshire
    This may help...
    http://www.vectra-c.com/forum/showth...34#post1301434
    I did mine a few weeks ago.. Filter was also tight in cage. Wiggle side to side and push from the bottom good luck..
    Aug 2012
    Stockton-on-Tees
    Thanks for that. Although it stil says stick a screw driver behind the filter housing and twist to release the clip I'm assuming shame it doesn't show what cop your releasing. I'll have a go again though see what I can do. Try tighten it more or slacked what ever the case may be.
    Aug 2012
    Stockton-on-Tees
    Might actually be leaking from the top pipe seal and not the main seal now. Is it possible to change the seal on the top pipe?
  1. fuel filter housing leaking
    By diesel_carp in forum Engine & Drivetrain
    Last Post: 4th March 2013, 17:02
  2. 1.9 cdti vectra fuel filter leaking
    By felix_19 in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2012, 16:47
  3. Leaking oil filter.
    By xoborp in forum Engine & Drivetrain
    Last Post: 25th September 2011, 17:45
  4. Leaking filter
    By anthonynoelg in forum Vectra C / Signum Troubleshooting
    Last Post: 4th May 2011, 08:33
  5. oil leaking from filter housing
    By dicky3706 in forum Engine & Drivetrain
    Last Post: 30th November 2010, 11:01
vauxhall vectra c fuel filter leaking
leaking fuel after i changed fuel filter on vectra diesel
leaking fuel filter on vectra
