Thread: Turbo intake pipe
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Turbo intake pipe
    So - doing a turbo change for someone on here (yeah ok thats ruined my other thread - LOL)...
    Looked at the air intake to the turbo and it was all nice and tight BUT saw this (pics below - once removed)...
    Now - it wasnt leaking air - and a rubber sleave does sit in it - but I am not sure this should be re-fitted due to the fact that I know its broken!.
    @nutron - have you seen these break like this on the car? and have you fitted one back like this?
    I just dont want to re-assemble for it to now leak and have to strip down again - but I know they are not cheap!
    Thoughts
    Pic showing break with the sleave in place so how it would sit on the turbo intake:
    Pic showing how the sleave sits insite it...
    Note of course that a jubilee clip goes round this securing it to the turbo...
    Thoughts?
    Middlesex
    Trim : SRI
    Mileage : 100k
    I've just been having another look at it. where the jubilee clip goes, the plastic isnt complete anyway as it has the slits so it can close on the sleave.
    So - I think if I use a new jubilee clip which is slightly wider whcih I will anyway - I am sure this will seal.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    Personally I'd replace it.
    Administrator plasma's Avatar
    On the Forum
    548 Post(s)
    Engine : 150
    Mileage : 74000
    As above, might be worth while holding of refitting until replaced in case it cracks a bit off and flies into the engine
    Middlesex
    Trim : SRI
    Mileage : 100k
    Yeah I will be at VX in the morning hoping they have one!
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If they haven't and the car is needed.
    do a temporary repair with some 2 pack glue. Any of the squaddie mechanics out their will be familiar with but of battle damage repair lol
    build it into hole carefully and should set solid enough to camp tight against until the pipe arrives.
    as I have a feeling it'll be a 2 day order on it
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Critch View Post
    I was thinking that if I do use this that I can glue the sleve in place with araldite. I honestly think it will seal fine. There is a lip on the sleve as you can see - and once clamped it should be fine.
    I suspect as you say - it will be a factory order.. Seen one on eBay 2nd hand for £50!!! JEEZ - how much will it be new!!
    My other thoughts too are that without stripping out the rad pack - or at least moving it forward - it will be VERY hard to change...
    Dec 2010
    Glasgow
    Mileage : Near 100K
    Quote Originally Posted by AntSSSS View Post
    They arent bad to remove, but are a f'n pain to get back onto the turbo as they are a tight fit.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by XPCobra View Post
    Exactly
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I've never seen one of those break but I have replaced mine with silicone pipes. I'd not put that back myself either, drawing in dirty air there would chew up the aluminium compressor rapidly.
  1. Afm to turbo intake pipe??
    By swifty_53 in forum Diesel Engine related
    Last Post: 28th September 2019, 17:47
  2. GSi/VXR intake pipe
    By Piemyster in forum Petrol Engine related
    Last Post: 19th July 2011, 11:34
  3. Intake pipe
    By starykokot in forum Petrol Engine related
    Last Post: 22nd January 2011, 20:22
