Results 1 to 10 of 22
Thread: Oil in cooling system
    Nov 2009
    manchester
    Vehicle : 1.9CDTI 150
    confused Oil in cooling system
    !.9cdti.. Just finished work early as car seems to be running hot. Had a look under bonnet and released the coolant header tank cap to find what I can only describe as a chocolate coloured expanding foam like substance over flowing out. Is this the head gasket or is there something else that can cause this... TY...
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Oil to coolant heat exchanger (sometimes called an oil cooler)? They have been known to fail resulting in oil/coolant mixing.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Not sure if these have an oil cooler or not.
    if not could be head gasket
    Nov 2009
    manchester
    I think they do have one but is there a how 2 on this...
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    just found this
    The cooler is next to the oil filter at the back of the motor and has an inlet and outlet coolant hose and is held on by 3 bolts , there is a picture below.
    I hope this helps , best regards XXXXX XXXXX
    op said his ran hot too.
    South east
    Is it a manual or automatic?
    Nov 2009
    manchester
    manual
    Mar 2013
    Castleford
    Vehicle : 1.9 TDi SRi
    Engine : 150bhp diesel
    Mileage : 65000
    Just my opinion but I would have opted more for the oil cooler if has one(?) if not head gasket but usually you would see evidence of coolant going in to oil rather tha oil into coolant if head gasket had gone. Is your oil as it should be?
    Nov 2009
    manchester
    oil seems ok however the level has dropped nearly off the stick which tells me its oil going into water. I take it the cooling system is going to take some flushing out. Very messy indeed...
    Mar 2013
    Castleford
    Mileage : 65000
    Quote Originally Posted by Nez View Post
    If it's the head gasket the flushing out of the coolant system will be the least of your problems. I would think changing the head gasket wont be cheap!!!
  1. Cooling system
    By jamiedvvt in forum Engine & Drivetrain
    Last Post: 18th March 2013, 09:50
  2. Cooling system help
    By Tinks in forum South Central (ARO - Brady )
    Last Post: 11th December 2012, 21:37
  3. cooling system problems
    By vmb2722 in forum Vectra C / Signum Troubleshooting
    Last Post: 20th July 2012, 19:59
  4. Cooling system
    By Tinks in forum Engine & Drivetrain
    Last Post: 21st April 2012, 10:43
  5. some probs cooling system
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 18:00
vectra z19dt oil filter cooler leaked www.vectra-c.com
Vectra c 1.9 cdti oil in water
opel 1.9 oil in coolant
