Thread: Been offered a cdc40
    Nov 2012
    Stoke-on-Trent
    Default Been offered a cdc40
    Iv been offered a cdc40 opera and gid for £70+ my cd30 and screen, is that a good price? Also the cdc40 came out of a prefacelift car but mines a facelift, will that matter? There both paired together so im asuming they will be a straight swap?
    Mar 2012
    Dundee
    Vehicle : GSI
    Trim : (vxr/irmy)
    Engine : 3.2 v6
    I paid £50 for my cdc40 from ebay, it would have came out a prefacelift full can
    Nov 2012
    Stoke-on-Trent
    I cant find them cheaper than £100 on the bay, im assuming its come out of a prefacelift car as it has the none chrome vents with it
    Regular Member rozzer2006's Avatar
    Jun 2009
    Glasgow
    Vehicle : vectra
    Trim : VXR
    Engine : 2.8 v6 Turbo
    Mileage : 50k
    as far as i am aware the cd40 is a full canbus headunit, ask for a picture of the plug at the back if its the black farkar one and not the blue ISO one it should be ok, and yes the screen and headunit are apired so u will need them both.
    Moderator paulhb's Avatar
    Wondering lonely as a cloud
    27 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    You also need the aerial and separate dab unit plus wiring loom if you want dab and the dab unit needs to be unpaired from the doner car or its gets expensive getting the security chip changed.
    Regular Member Robsey's Avatar
    North East Cheshire
    26 Post(s)
    Trim : Energy
    Mileage : 150,000
    Okay -
    Yes CDC40 is Full CAN, so connectivity is no issue.
    The display connector "may" need an extra +12 volt wire on pin 3 and / or an extra ground on pin 1 to run a GID.
    If you are JUST fitting the CDC40 and the GID and they are still paired to each other, then they should more-or-less just plug straight in with no programming required.
    Programming will be required if you are using the BC function, or it is not configured to your set-up (fuel type, add-on heater, ECC etc).
    If you want DAB, then you will need a DAB unit, DAB Aerial and the loomage to link them.
    The DAB unit would need to come as part of a complete package (with display and head-unit), or would need to be divorced if supplied on it's own.
    If you get the DAB separately,
    You WILL need Tech 2 / Vauxcom to divorce your current set-up, and then get the whole lot married up together.
    If you are getting this programmed by a dealer, you need to factor in as much as £80 for this service... cost depends from dealership to dealership, and also from one technician to another.
    I have heard of others getting it done free and others for as little as £25, but these are not common.
  1. CDC40 to CDC40 MP3 upgrade.... any advice?
    By eamond in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2012, 08:02
  2. been offered this on swapz
    By srikev in forum The 'Off Topic' room
    Last Post: 19th September 2011, 19:20
  3. Been offered another job but......
    By FIL 4822 in forum General Chat
    Last Post: 3rd May 2010, 15:19
  4. opc maps have a 3 and been offered more
    By chrisgettings in forum Diesel Engine related
    Last Post: 4th October 2008, 10:07
