Thanks Thanks:  1
Likes Likes:  4
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 74
Thread: 1.9 CDTi Swirl Flaps - What, Where, Why and How Much?
  1. #11
    mattcarpenter10
    Guest
    Anyone
  2. #12
    Jul 2013
    redditch
    Vehicle : vectra c
    Trim : sri
    Engine : cdti
    is the judder about 1600-1700rpm? if so mine does the same..never figured mine out and no fault codes get stored..
    there is a kit to remove the swirl flaps and you leave the motor connected to the plug how this affects power i havent a clue as yet but as i have a scrap manifold I am going to give it a try soon..
  3. #13
    Mar 2011
    Bulgaria
    I did not notice any difference, although I was definitely loosing pressure from the worn bearings.
    This is how it looks b4 and after... Just leave swirl motor in place...
  4. #14
    Apr 2012
    South Wales
    Quote Originally Posted by kingarthas View Post
    Did you change the Swirl actuator - 55205127 aswell?
    or is that Swirl motor to left in place?
  5. #15
    Sep 2013
    Hertfordshire
    Trim : SRi XPNAV
    Engine : 1.9 CDTi 150
    @kingarthas where did you get the blanking kit from? I did a simolar thing to my 320d before and it worked a treat.
  6. #16
    Regular Member Elite3.0v6CDTI's Avatar
    Apr 2012
    Harlow
    Mileage : 140000
    My swirl bar sits to the right 1o'clock position all the time wether the engines running, off or revving. They don't move at all. Are they stuck in the open or closed position? I'm suffering problems like hardly any boost and am running out of ideas and just checked these flaps. The manifold isn't even a year old, I dunno if this has always been like this since the garage fitted the manifold..
    Darrell
  7. #17
    Mar 2011
    Bulgaria
    Sorry for delayed answer...
    "or is that Swirl motor to left in place?" - YES it is. No need to touch. Leave the car think that it is all ok . If you have problem with motor itself then you should map it out. You can check my tunning guide in the tuning section.
    I dont got any blanking kit. I got a turner friend, he got a workshop for fixing car engines. In fact many motor shops send engines to him for repair. Should have one like him in your place too . As per his words, his work cost about 20 euro. Removing manifold will cost you more.
    In my case was really sad story, as my cooling pump stuck and broke the cam belt, rocker arms and valves. It cost me 450Euro to repair. And they return the car as it is on the first pic, w/o saying a word. Then the winter come and I was force to change the original (6 years old) glow plugs and I found the fallen swirl bar. Then I was forced to pay again for manifold removal. So i still swear those bast*ards that took 450E and did not said a word about the swirl.
  8. #18
    Jul 2013
    redditch
    Vehicle : vectra c
    Trim : sri
    Engine : cdti
    flap removal blanking kit..As yet I havent bought a kit as not sure if it makes them worse to drive..from what i have read you loose a bit of low down torque.but a remap can cure that
    http://www.ebay.co.uk/itm/1610911364...84.m1436.l2649
  9. #19
    Oct 2013
    Brecon
    Trim : SRI (150)
    Engine : 1.9CDTI
    With no swirl flaps, is that good for the engine, i suppose you'll have all sorts of **** going in there then...
  10. #20
    Nov 2013
    Hertfordshire
    Vehicle : Vectra sri 150
    Trim : Sri
    Engine : 1.9
    Hi, just bought the de-flap kit and a new inlet gasket but someone mentioned online about a new pump but that needed to be fitted as they needed to remove it when fitting the kit, also is there anything else I need and what time if sealant do I need to crack open the manifold to clean it and put back together.
    thanks
  11. Thanks v6nce thanked for this post
  1. Swirl Flaps what year? 1.9 cdti
    By caigey in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2013, 20:50
  2. CDTI swirl flaps sticky?
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 13th March 2013, 19:36
  3. cdti 120 swirl flaps
    By jymercer in forum Engine & Drivetrain
    Last Post: 12th August 2012, 00:12
  4. Cdti swirl flaps
    By rob1981 in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2012, 07:29
  5. Swirl valve flaps on a 150 cdti
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2011, 19:37
1.9 cdti swirl flap symptoms
vectra cdti swirl flap symptoms
https:www.vectra-c.comforumshowthread.php184055-1-9-CDTi-Swirl-Flaps-What-Where-Why-and-How-Much
P2279 opel zafira
cdti swirl flaps
p2279 z19dthvectra 1.9 cdti swirl flapsp2279 opelvectra c swirl flapsOpel P2279vauxhall swirl flapsp2279 opel 1.9 cdtioperation of swirl flaps on vauxhall saab turbo diesel enginesswirl flaps vauxhall zafiraSwirl flap symptomsswirl flap failure symptomsastra swirl flapsswirl flaps vectra cz19dth swirl flapsvectra 1.9 cdti 150 manifold problemsastra 1.9 cdti swirl flapsp2279 zafiravauxhall astra twirl valvesp2279 zafira z19dthvectra swirl flaps
Tags for this Thread
