Thread: clunky steering and car vibrating too
    Nov 2012
    trowbridge wiltshire
    Trim : Gsi
    Engine : 3.2 v6
    Mileage : 160k
    Default clunky steering and car vibrating too
    hi guys.
    1 : low speeds like coming off my driveway i get a clunking sound as i steer ???? really sort of 'twoingy' ish
    and 2:
    when i get to about 50mph or higher the car seems to vibrate , like at night you can see the headlights shaking on the road - the only odd thing is that if i let off the throttle it goes away, put my foot down lightly and its there and if i floor it in 5th whilst im doing for instance 60mph its there fully shaking lol.
    the car seems absolutely fine mechanically , all tyres are straight and balanced with same psi all round. the shaking doesnt come through the steering wheel but more through the actual car itself if that makes any sence ..
    anyone come accross this lol
    Regular Member Niall83's Avatar
    Nov 2009
    Belfast
    Sounds like me at the min. Clunking when turning, could be the CV joint. Think my problem is the gearbox
    Nov 2012
    Trim : Gsi
    Engine : 3.2 v6
    Mileage : 160k
    oooooo gearbox yay lol have you seen the prices of them on ebay ! then you have clutch and duel mass flywheel . !!!!!
    Regular Member any-mgzt's Avatar
    cheshire
    9 Post(s)
    Trim : basic
    Engine : Z19DT
    If the sound you get is a "twoingy" as you say, then it say to me its a road spring broken, same thing happened on my sons SEAT Leon, and I have it now on the Veccy, new springs on order, will fit when SPRING actually arrives and temperatures rise.
    Jack it up and sit it on axelstands and get someone to turn the steering from lock to lock while you look at the springs in turn, if it goes "twoingy" you will see it vibrate noticably.
    I never heard of a CV joint failing and making a twoingy sound, usually more of a knock sound.
    12 Post(s)
    Quote Originally Posted by any-mgzt View Post
    If the sound you get is a "twoingy" as you say, then it say to me its a road spring broken.
    Or it could be the top strut bearing. One of mine is shot and I can't get it looked at by the garage until next Tuesday!! I'd do it myself but I just don't have the time and it isn't great weather to be handling cold spanners.
    Nov 2012
    Trim : Gsi
    Engine : 3.2 v6
    Mileage : 160k
    yeah my springs do move so new springs then , ive noticed on ebay lowing springs are only 80 quid for 45mm all round so might get them on the old girl :-) once thats done it will just be the vibration to look into unless it could also be the springs ??? hmmmmmmm :-)
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Inner CV joints maybe? My first Veccy had similar symptoms and it was cured with new inner cv joints
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    10 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    With the car stationary and the engine running, rock the steering side to side slightly, does it make a noise then?
    Aug 2012
    Scottish Borders
    Sounds more like top strut bearings.
  1. Clunky knob
    By Timkel in forum Vectra C / Signum Car Chat
    Last Post: 5th June 2011, 21:38
  2. clunky brakes
    By craigbarlow18 in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2009, 16:57
  3. Clunky all round
    By s1nglef1sh in forum Handling & Braking
    Last Post: 13th April 2009, 21:32
  4. Steering wheel vibrating side to side
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2008, 19:32
  5. Vibrating steering wheel
    By Matt21385 in forum Vectra C / Signum Troubleshooting
    Last Post: 29th November 2006, 23:43
