Thread: Dropping Front Tyre size from 215/55/16 to 205/55/16
    Mar 2013
    Scotland, North East
    Vehicle : Saab 9-3 (Vectra C in disguise)
    Trim : Linear Sport
    Engine : 1.9 TiD 150
    Default Dropping Front Tyre size from 215/55/16 to 205/55/16
    So given that one of my front tyres is getting a bit low on the old tread (grip in the snow is nearly nil)
    Figured might as well swap both front tyres as the other is about half worn
    Car came with 215/55/16 fitted, but considering fitting 205/55/16 as better range of tyres and at least £16 cheaper per tyre for identical tyres (sometimes a lot more)
    Will this cause any major handling issues?
    Thoughts?
    Dec 2011
    Seaham
    I beleive some of the earlier Vectras had 205/55/16, there are two categories for speedo readings in the computer. If your car had standard 215/55/16 then it will be a category 2, you may need to change to a category 1 to keep speedo accurate.
    Try this company for tyres.
    http://www.mytyres.co.uk/cgi-bin//rs...e=10&weiter=70
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    It should not be a problem, the two tyre sizes are in the Owners Manual I have. I have also run both sizes, at different times, without any problems.
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    My steel winter winter wheels are fitted with 205, 55 , 16's with 215's on the summer alloys. From the sat nav, I'm about 4mph out at 60 indicated
    Mar 2013
    Trim : Linear Sport
    Actually I did look there first, considering Avon Ice Touring ST tyres and just leaving them on all year long, mileage I do isn't scary, but I live at a reasonable altitude so snow isn't exactly uncommon in the winter (well this year has been overly common)
    Wirral, UK
    Vehicle : Mokka
    Engine : 1.7CDTi
    I fitted a full set Continental TS830's and left them on over summer on my last Vectra.
    They are supposed to wear out more quickly in hot weather and not stop the car as good as summer tyres in hot weather, but I didnt notice any difference.
    I now have 2 sets of wheels for my current Vectra (16" wheels are usually cheaper on ebay cos' everyone wants 17" wheels) and bought part worn TS830's which are currently fitted.
  1. Front Windows Dropping
    By Sparky67 in forum Bodywork & Interior
    Last Post: 9th January 2012, 22:13
  2. Wheel size and tyre size
    By DSmiddy in forum Vectra C / Signum Car Chat
    Last Post: 14th December 2011, 19:19
  3. tyre size
    By gibbon7000 in forum Suspension, Wheels & Brakes
    Last Post: 9th November 2011, 20:12
  4. Best tyre size?
    By arkhan78 in forum General Chat
    Last Post: 29th June 2009, 06:31
  5. tyre size?
    By bravocorsa in forum Handling & Braking
    Last Post: 22nd March 2008, 19:35
Private. Seller. Tyres 2155516
vectra c 215 or 205 tyres
2055516 tyre for vectra
vectra 215-55-16
205 55 16 on vectra 2007
can i replace 21555 with 20555
vectra c 2055516 tyre
vectra 2155516 recommended tyre
change 20555 for 21555
