Thread: Xeon headlights what do i need to fit vectra c sri
    Jul 2011
    gateshead
    Default Xeon headlights what do i need to fit vectra c sri
    Hi all my mates breaking a vectra with xeon headlights in he said i can have how will these fit in my vectra c sri, are plugs the same, and i know on a mk 2 vectra you need the power balast behind wing is this the same with a vectra c thanks in advance frankie
    Dec 2011
    Seaham
    If they are aftermarket Xenons, you need the H7 bulb and the ballasts and its a simple wire in case. If they are factory fitted, then there is a lot more wiring etc needed.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 85000
    If its a factory set up the Balast is already fitted to the underside if the headlights, but the plug is different and you need to run an extra wire too. Then you would also need to retrofit the auto levelers and wiring, as the xenon set up uses a different headlights switch too. tbh its easier to fit an aftermarket set up.
    Jul 2011
    gateshead
    They are factory ones sounds like a mission thanks fir the replys but think i will just leave the angel eyes in as i will probz melt car
    Dec 2011
    Seaham
    You can buy aftermarket kits for around £20-£30, have the Xenon option switched on by tech 2 Opcom, no cancellers required and Bobs your Uncle!!
  1. Vectra C headlights
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 16th May 2012, 19:45
  2. GAS DISCHARGE Xeon lights
    By m3ath3ad in forum Electrical & ICE (including SatNav)
    Last Post: 10th March 2009, 23:18
  3. Xeon Headlights
    By Mark2.2 in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2008, 18:56
  4. AFL xeon lights?? what are they worth?
    By lee_eardley in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2007, 15:10
