Thread: Power steering warning light ?????
    Nov 2012
    Derby
    Vehicle : Vectra 1.9 CDTI 120
    Trim : Energy
    Engine : 1.9 8v 120 BHP
    Mileage : 170, 000
    Default Power steering warning light ?????
    2004 vectra c 1.9 8v
    My alternater packed up the other day with smoke coming out of it. Had it replaced along with new belt and tensioner. It started up fine and is charging the battery ok and giving off 14v however the power steering warning light has come on and wont go off ???. Steering appears to work fine. Any idea's ????.
    Nov 2012
    Derby
    Trim : Energy
    Mileage : 170, 000
    Anyone ?
    Regular Member any-mgzt's Avatar
    cheshire
    21 Post(s)
    Trim : basic
    Engine : Z19DT
    I had light come on on mine, shortly after I replaced Alternator. The alternator is a sod to get out through the top of the engine bay, if your fuel filter will not come out, I took the easier option of removing driverside wheel, drop link and got it out that way fitting is reverse.
    Anyhow, my point if the garage who did your alternator did it that way they may as I did just catch the wiring on the steering sensor, and snap on off. Check the sensor wiring at the connector, should be 3 wires coming out of it.
    As I said I did that and did not notice, not sure I actually broke it right off as the light did not come on until a couple of weeks after the alternator change, I may have damaged it enough for vibration to finish the job..
    Nov 2012
    Derby
    Trim : Energy
    Mileage : 170, 000
    Thanks for that. That's exactly what happened. Gonna have to strip it right out to see if the sensor is damaged.
  1. Power Steering Warning Light
    By MrDerv in forum Electrical & ICE (including SatNav)
    Last Post: 23rd July 2014, 19:49
  2. Steering wheel warning light , no power steering!
    By Domchapp in forum Vectra C / Signum Car Chat
    Last Post: 23rd July 2012, 22:11
  3. power steering warning light!
    By mick 1986 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2010, 20:36
  4. Power steering warning light
    By neil1194 in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 09:53
  5. Power Steering Warning Light - Ugh!
    By Leviathan in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2008, 17:25
vectra c power steering warning light on wont start
vectra c powersteering light wont turn ovet
