Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Vectra c z20net help !!!
    Regular Member matrix1979's Avatar
    Aug 2007
    NORFOLK
    Default Vectra c z20net help !!!
    Hi all , I'm not sure if anyone can help but my 2.0 turbo (z20net) is still running rough on idle and is running to rich , mpg has dropped ,plus its smells really gasy coming out of the rear exhaust boxes . I have tryed many things to sort this issue but no luck , things I tryed are .... New coolant temp sensor , new plugs , new lamda sensor , new throttle body , fuel filter , maf sensor , checked compression test ..ok , coil packs checked ok , if anyone can help I would be very greatfull ,,,, mark .
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Tech 2 or Vaux-Com session is needed.
    South east
    Any warning lights showing on the dash?
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Are there 2 lamda sensors on the Z20NET? Have you replaced both?
    Aug 2007
    NORFOLK
    Quote Originally Posted by Chunklamb View Post
    Yer there are 2 lamdas on the z20net one pre cat and one post cat but i didnt think the one situated on the exhaust under the car would nt be the issue
    Aug 2007
    NORFOLK
    Quote Originally Posted by Rebellion View Post
    yes the engine managment light have been on in the past but will go out again automatically shortly after ... had it read and the codes were...(PO171 System Too Lean Bank 1) and P0300 Random/Multiple Cylinder Misfire Detected .
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    I had to replace lambda 2 in the exhaust centre section. Its attached back to the engine bay witha long cable but I cut the wiring and joined the new one on.
    Regular Member PCMALT's Avatar
    Jun 2011
    Peterborough
    Vehicle : Signum V6 CDTI
    Trim : Custom lol
    Engine : Y30DT
    Mileage : 24000
    normally if it is a lambda fault then the EML light would come on, Have you checked the condition of the filters ie fuel and air as these can effect fuel economy and general fuelling but as said before i would get it on diagnostics and see what's going on there run live data and see what the lambdas are doing.
    Aug 2007
    NORFOLK
    Quote Originally Posted by Caveman_nige View Post
    Did you have the same symtoms as i had nige and it cured it with changeing lambda 2 on the exhaust ?
    Aug 2007
    NORFOLK
    Quote Originally Posted by PCMALT View Post
    normally if it is a lambda fault then the EML light would come on, Have you checked the condition of the filters ie fuel and air as these can effect fuel econemy but as said before i would get it on diagnostics and see whats going on there run live data and see what the lambdas are doing.
    Yer i have checked the filters and replaced all
  1. vectra 2.0 turbo z20net lumpy idleing (can anybody come help )
    By matrix1979 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th April 2012, 23:22
  2. Vectra c 2.0t Z20NET low power
    By 2Oturbo in forum Engine & Drivetrain
    Last Post: 15th November 2011, 21:23
  3. Vectra 2.0t (Z20NET) - diesel sound?
    By buggy in forum Engine & Drivetrain
    Last Post: 19th May 2011, 09:13
  4. Vectra Z20NET Axle Weight?
    By Jezzy in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2010, 18:05
p0300 z20net
z20net pre cat
z20net p0300
