Thread: Vectra 150BHP Flickering Main Beam Lights
    Aug 2011
    Dudley
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTI 150BHP
    Mileage : 141000
    Default Vectra 150BHP Flickering Main Beam Lights
    Guys,
    Noticed my headlights have started to flicker very slightly and also the reversing lights dim when you turn the steering wheel which I believe is due to the current draw from the steering pump. Would this be a battery issue or the regulator/rectifier starting to break down in the alternator and pass some AC voltage. There is no battery light on the instrument panel when the car is running.
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    do your headlights flicker when on full lock?
    Jan 2012
    Silverstone village
    If you increase the revs does the flickering go ?
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    If it's just a slight flicker then it's quite normal - due, as you say, to the current draw of the power steering.
    Could it be that you've just never noticed it before?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    It could well be the battery dying, or just dirty connections on the battery terminals.
    When I replaced my battery for a much bigger one last year the flickering reduced and I hardly notice it now.
    Dec 2011
    Seaham
    Tony, the flickering will reduce as the bigger battery will help to smooth out the current demands of the steering.
    If you fitted a smaller battery, the flickering would get worse.
    Feb 2013
    velserbroek
    Vehicle : vectra c
    Trim : Wagon 1.9 cdti
    Engine : 120 ps
    Mileage : 225000 km
    Hi,
    My Vectra C - 120 BHP- year 2005 - 191.00 km, does exact the same, but the beams doesnt flicker when the engine is not running and the lights are on- My OPEL dealer installed a year ago a new dynamo -
    I also find the H7 beams not very powerfull-
    Greetz Jack
    Aug 2011
    Dudley
    Mileage : 141000
    Guys,
    They headlights flicker when the car is stationary and the steering wheel not being moved. A failing battery it well maybe, checked the voltage today without starting the car and it was 12.1volts. This could also be linked to my alarm going off for no reason.
    What would be the best size battery to get ?
    Jan 2012
    Silverstone village
    Quote Originally Posted by wheelspin View Post
    Guys,
    I recently replaced mine with a 80AH battery with 800 cold cranking amps.
    Original thread ,http://www.vectra-c.com/forum/showth...tery-Type-Size
  1. Main Beam Bulb...
    By chewy71 in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2010, 20:27
  2. Main Beam Adjustment
    By hefilump in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2009, 23:05
  3. Hids in the main beam...
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2009, 20:50
  4. Main beam bulbs
    By Bucko in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2009, 20:49
  5. Are the h/l and main beam bulbs the same ?
    By simac in forum Vectra C / Signum Car Chat
    Last Post: 19th December 2006, 22:13
