Thread: Boost on CDTI 120
    midlands
    Default Boost on CDTI 120
    Hello
    Is my turbo ******ed? What should the boost be at 2000 revs?
    Much higher than 1.1 psi?
    Steve
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    looks as you just sat reving it mate u need to put ya car underload
    Jan 2012
    Houghton Le Spring
    Vehicle : SRI 150
    Trim : Smart and Bad!
    Mileage : 105000
    If no boost or goes off boost while driving, check boost pressure sensor hoses. The 2-4mm hoses in front of engine. My brother in law had boost issue. I took a look and found flexi rubber hose has split! I replaced it with my silicone 2mm bore hose. Just a thought to jump the boat before u explain why u are investigating the issue if any :-)
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    what it will be is hes gor a new app and new toys and wants to see if it works lol but dont propaly understand how boost works thats all go for a drive steve and watch it jump up and down lol
    Regular Member C-Owner's Avatar
    May 2011
    South London
    One of the reasons they stopped putting oil pressure gauges in cars years ago, and some cars don't have temp gauges now........
    Just something else to worry about
    Some of those apps are quirky an not to be trusted as 100% correct.
    midlands
    Quote Originally Posted by paulvectrac View Post
    Ha - nah had the ap for a while to check for fault codes, but the car seems slugish lately, I can hear the turbo working but don't seem to get the torque i used to. However i did not realise it had to be under load - which when i though about it makes sense. Repeated the test today on way to work and maxed out about 25psi.
  1. 1.9 cdti boost gauge how 2
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 19th January 2013, 18:33
  2. v6 cdti boost
    By broad in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2012, 16:25
  3. CDTI 150, 10k Boost De-Coked & New Boost Sensor
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2010, 12:02
  4. Boost pressure on 1.9 cdti 150
    By andreitone in forum Engine & Drivetrain
    Last Post: 9th June 2009, 20:48
  5. 19 cdti boost problem
    By sri22dti in forum Engine & Drivetrain
    Last Post: 7th February 2009, 23:08
