Thread: Brake help please
    Jul 2009
    durham
    Default Brake help please
    57 vectra Sri 150
    had new discs and pads (original Vauxhall) fitted 6 months back my car now feels like handbrake is slightly sticking on.. No noise when driving or anything just slightly stiff when pulling away.. My questions are will kwik fit identify problem for me on a free brake check,what is it likely to be.. And what's worse case???
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Mine started to do the same was meaning to strip and clean up the sliders and rubbers, never got round to doing it the next thing I knew I went through a set of new pads in less than six months. I had to get a new piston as it was seized.
    So could do with cleaning up or you have a sticky piston.
    Nov 2012
    Holyhead
    Hi, replaced all four sets of pads/rotors two years ago. After that, the fronts in particular would "stick" on, cheap rotors off the net, but the calipers were "sticky" so have just replaced front calipers/rotors and pads, feels like a different car now. Got replacement GM calipers from Brakes Internaional in Rochdale, quite cheap (£120) for fronts and really good service. Talk to Sarah, she know's herr brakes!!
    i would suggest new calipers, you can get over-hauls kits, but you never know what lurks after you stip it down.
    Hope this helps............................................
    Ken
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    On the rear sliders remove the rubbers from the caliper and clean the holes mine had corroded so much it was squeezing the rubber and pinching the slider pins causing it to stick and bind as if the hand brake was still on
    Done mine no issues since
    crook
    As above....
    common fault for pins to seize .
    take pins out and clean and lube.
    take rubber out of caliper and clean the hole up.
    usually corroded up causing rubber to distort causing sliding action to stop
  2. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  3. yellow brake calliper brake set
    By The Gas Man in forum Parts for sale
    Last Post: 22nd July 2010, 22:41
  4. What brake pads for 2.8 V6 Signum??? 314mm brake discs
    By luke4487 in forum Suspension, Wheels & Brakes
    Last Post: 25th February 2010, 23:21
  5. Brake Pad
    By Gary1985 in forum Suspension, Wheels & Brakes
    Last Post: 3rd October 2009, 18:15
