Thread: Igniton wires? Please help
    Apr 2012
    east anglia
    Trim : Special Edition
    Engine : 3.0 CDTI
    Year : 56
    Mileage : 57,000
    Default Igniton wires? Please help
    Hi there I am trying to locate the starter motor wires from ignition barrel for a start button to work please could anyone tell me where the wires are located have taken all trim off around steering wheel and I'm unsure of weather I need to take steering wheel off or not to find big wires for starter motor any help would be very much appreciated! Thanks!
    Regular Member blue estate's Avatar
    oh well.. I tried..
    Personally i think you'll be ****ing in the wind on that one.. its controlled by the CIM and and far as im aware its not going to be possible to do.
    I know your thinking old skool Vauxhall with the switch box on the back of ignition which had the larger wires your looking for
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    You won't find any 'big wires' from the ignition switch to the starter. The starter relay is driven by a signal from the ECU.
    I can't really see the point of a start button anyway as you would still have to have the key in the ignition for the immobiliser to work, and then there's the steering lock.
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Cim controlled mate.
    Is their much point when you need key in ignition still?
  1. Igniton Problems
    By thehitman1967 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2012, 14:54
  2. Help required please on HID wires
    By DTI Dave in forum Electrical & ICE (including SatNav)
    Last Post: 7th February 2012, 21:47
  3. What are these wires?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2011, 14:18
  4. help with wires
    By simon5800 in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2009, 16:01
  5. what are these two wires for?
    By JammyBStard in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2008, 19:25
vectra c starter motor wiring
vectra c which wires go from ignition to starter motor
