Results 1 to 10 of 14
Thread: diesel fuel pump
    Regular Member Daniel Dixon's Avatar
    Jan 2013
    United Kingdom
    Vehicle : vectra c
    Trim : LS
    Engine : 2.0 DTI 16v
    Year : 2002
    Default diesel fuel pump
    looking for a cheap diesel fuel pump for a 2.0L vectra c 52 plate. have trouble starting affter car sits for 2 days as diesel runs back into tank
    Regular Member spikeyboi33's Avatar
    Jan 2013
    Ireland/Poland
    Vehicle : Vectra C Prefacelift.
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    Have that same problem even after a few hours.. How do you know its the pump and bleeding the system won't solve the problem ?
    Jan 2013
    United Kingdom
    Vehicle : vectra c
    Trim : LS
    Year : 2002
    its got symptoms of the fuel pump going but ive had people say its the injector seals not holding the pressure so thats y the diesel runs back to tank but im going to ask vauxhall see if they no the problem
    Jan 2013
    Ireland/Poland
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    Id hook it up to a com aswell, maybe some codes pop up, need to do the same to mine.. let me know what you find out
    Jan 2013
    United Kingdom
    Vehicle : vectra c
    Trim : LS
    Year : 2002
    yeah i will do mate will inbox with what comes up
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Maybe be a bit more precise on your location, United Kingdom is a tad large.
    Injector seals and leak off pipes are a favourite on the DTi. The kit to replace them is about 30 quid all in from Vauxhall if I remember right. It's pipes and the little T pieces I believe. Park it facing down hill if you can. Even if it means parking it up on a couple of blocks at the back. Just raise the back end up and leave it as long as possible. If it starts better/normally, then it's going to be the leak off pipes or seals. More than likely leak off pipes - they perish.
    Jan 2013
    Ireland/Poland
    Trim : "Elite"
    Engine : 2.0dti
    Mileage : 130,000
    Better that than a whole new diesel pump... prices are threatening!
    Jan 2013
    United Kingdom
    Vehicle : vectra c
    Trim : LS
    Year : 2002
    it was at the garage today and was on the computer and a malfunction in the injector pump was causing the problem :/
    Oct 2012
    uk
    where abouts are you I have a cheap pump for sale
    Regular Member krazylegz's Avatar
    South Shields
    could be a false code generated as the seals or leak off pipes won't have a dedicated fault code.
    I would seriously try the injector seals or leak off pipes before splashing out on a pump, I've had 3 DTi's and all had this problem and changing the seals on all have cured it
  1. Signs & Symptoms of a Bad Diesel Fuel Pump
    By Madmarky01 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th August 2012, 21:13
  2. Signs & Symptoms of a Bad Diesel Fuel Pump
    By Madmarky01 in forum Vectra C / Signum Car Chat
    Last Post: 4th August 2012, 20:35
  3. Replies: 19
    Last Post: 30th May 2012, 15:53
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  5. diesel fuel pump kaputt
    By onksy in forum Engine & Drivetrain
    Last Post: 3rd April 2007, 07:41
vauxhall signum 1.9cdti cuts out at certain temperature
