Results 1 to 3 of 3
Thread: Fuel pick up pump
    Jan 2012
    Milton keynes
    Trim : M Sport and Design
    Mileage : 38100
    Default Fuel pick up pump
    Has anyone ever had to replace this?
    Our car was in having some work done today and they kindly put it thru a Tech 2 session at the same time. They noticed the semi-blanking plate on the EGR valve LOL and mentioned that the "In tank fuel pick up pump" was noisy and wasnt running as it should. I mentioned the poor starting after being sat overnight and he mentioned that this pump is used to prime the system.
    Anyone any experience of having this replaced and rough cost etc?
    Z19DT
    Regular Member stret's Avatar
    Oct 2012
    east midlands/westmidlands
    28 Post(s)
    Vehicle : signum
    Trim : elite
    Engine : 1.9 cdti 16v 225bhp
    Year : 54
    Mileage : 150k
    i used to work at diesel specialist garage as a tea boy/ labourer when i was 14-16 and used to recon these its quite a simple process and think most diesel specialist will do this for you or swap yours for one they have reconned off the shelf much cheaper than a new one, dont really answer your question but may be worth looking into rather than taking to a regular local garage
    Jan 2012
    Milton keynes
    Mileage : 38100
    Bumpity bump
  1. Fuel Pump
    By Johnty in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2012, 23:29
  2. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  3. Replies: 19
    Last Post: 30th May 2012, 15:53
  4. high pressur fuel pump and fuel regulator ?
    By simplesi in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2010, 12:23
  5. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
