Thread: Looking for a LUK flywheel(1.9CDTi)
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Default Looking for a LUK flywheel(1.9CDTi)
    Afternoon everyone.
    I'm looking for a LUK flywheel for a 1.9 150. Anyone know the best (ie. cheapest) place to pick one up from?
    Regular Member Hyperhart's Avatar
    Jan 2010
    Luton, Bedfordshire
    Vehicle : Astra GTC VXR
    Trim : VXR
    Engine : 2.0t
    Try euro car parts, i've been quoted around £400 for one on the VXR.
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    39 Post(s)
    Engine : 1.9 DTH
    As above 202.50£ with 25% discount code
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    lmf vauxhall have genuine (sachs) boxed ones for £199 plus delivery i think if you go aftermarket get a sachs one as it will be identical to the vx one (well should be)
    Wirral
    10 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    Balls I'd forgot about ECP! It's the LUK one I'm specifically after, they're holding up to the higher torque of the hybrid turbos much better than Sachs ones.
    Cheers guys.
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Mileage : 166000
    ah fair enough im always warey of mickey mouse flywheels as when i was at vaux we had a 3.0 cdti siggy come in that had a mickey mouse flywheel and the hole locations wernt deep enough causing the bolts to bottom out in the crank and torque up without actually fixing the flywheel tight to the crank, the resultant loose flywheel did the cranks and the vibration cos the guy kept driving it also knackered the timing gears Turning the engine into a very large and oily paper weight lol. but if the luk ones are known to be good i cant see a problem, would be interested to hear more about them being more robust. am already starting to gather together my options when it comes to uprating my clutch as after 30k and a bit of hard mostly remapped miles my clutch isnt feeling its best (i know, im a clutch killer, i drive my car hard and i dont mind admitting it, im not gonna spend lots of money tuning it to drive it like a granny, and racing and beating chavvys in saxos is too much fun )
    Regular Member blue estate's Avatar
    oh well.. I tried..
    If you can actually collect the DMF if using ECP.. the box may well be an LUK one but the contents might not be.. found this a few occasions now. They got a container load direct from LUK hence why they are so cheap to buy from them compared to other places.. but also 'spare boxes'
    May 2013
    London
    Vehicle : Vectra 1.9CDTi 150
    Trim : ELITE
    Engine : Diesel
    Year : 57
    Mileage : High :-)
    Hi all,
    I'm looking for a replacement DMF / Clutch kit for a late '57 CDT1 with engine type Z19DTH, 6 speed box and I need to find out exactly which gbox I have, but no-one can tell without disassembling under the bonnet. I want to source the parts online and get my local garage to fit and save some ££'s - can anyone point me in the right direction please? If you need more info let me know. Thanks
    Dec 2010
    Glasgow
    Vehicle : 1.9 Cdti Signum
    Engine : z19 DTH
    Mileage : 160000
    stand facing your car, with the bonnet up - take the engine cover off, on the RHS is where your gearbox is. Look past the battery and down towards the floor - hopefully you will see a cast metal bit - its massive, on there it will say what you gearbox is, my guess would be it says F40
  1. 1.9cdti clutch and flywheel change
    By danny_n in forum Engine & Drivetrain
    Last Post: 13th July 2011, 21:57
  2. 1.9CDTI 150 clutch / flywheel issue
    By LGD in forum Engine & Drivetrain
    Last Post: 28th January 2011, 00:29
  3. 1.9CDTI 120 Dual Mass Flywheel...
    By danBoy in forum Parts for sale
    Last Post: 6th August 2009, 20:37
  4. 1.9cdti sri flywheel
    By PAULMAC77 in forum Engine & Drivetrain
    Last Post: 8th September 2008, 16:46
