Thread: Does your Vectra vibrate (1.9 cdti 150ps)
    Jul 2009
    wishaw
    Default Does your Vectra vibrate (1.9 cdti 150ps)
    Hi
    I have just bought a used Vectra and it had the DMF & Clutch replaced under warranty (2 month Arnold Clark warranty) because it was rattleing when i pressed the clutch in a bit.
    Now my problem seems to be when the car is sitting idle there seems to be a bit of vibration through the steering wheel and feels like the seat is vibrating and also the keyring on my key shake as well.
    Would this be normal for the 1.9 cdti or does this seem a bit much and also what could be causing this?
    Jul 2011
    UK
    Year : 06
    Switch the dildo off lol.
    More serious note mine don't vibrate.
    South east
    It could be caused by worn rubber in one or more engine mounts.
    Jul 2009
    wishaw
    I never noticed this before they replaced the dmf & clutch not sure what it could be car drives perfect & also engine doesnt seem to move much.
    Regular Member astradriver's Avatar
    Dec 2011
    Slovakia
    My 2006 hatch also started vibrating after DMF and clutch replacement. When they do the replacement they have to put the gearbox out of the way (obviously) and I think they also lower the engine a bit which means they mess arround with the mounts too. I noticed though that when it warmed up it stopped vibrating to the extent that I was not noticing it.
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    my 56 cdti 150 @ 140k new dmf @ 112k steering wheel vibrates and also wobble/shudder if i hold the revs at 1600-1800
    May 2006
    scotland
    My car wobbled and a lot of people are really sceptical when I tell them that resetting the electronics (disconnecting the battery for an hour) solved my problem. This is true and it has been 1 year and 10k miles and never wobbled again to date.
    Jul 2009
    wishaw
    Quote Originally Posted by wickedwillie View Post
    I think they had the battery disconnected when replacing as everything was reset. Might take the car back to them to get it checked. As said in previous post it seems to get better as it get warm
  1. Vectra 1.9 CDTi, 120 ps 8 valve or 150ps 16v
    By Pepsi Max in forum Vectra C / Signum Car Chat
    Last Post: 23rd October 2012, 21:10
  2. 1.9 CDTi 16v 150PS EGR Valve
    By SRiXPT in forum Parts for sale
    Last Post: 26th June 2010, 22:17
  3. New Car: Vectra SRI 150PS!!
    By barkzz in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2009, 11:29
  4. 1.9 150ps CDTi Power drop in first
    By bandrew in forum Engine & Drivetrain
    Last Post: 21st August 2006, 21:19
