Results 1 to 10 of 17
Thread: Changing the PGS16 diesel pump on a Y20DTH
    Mar 2013
    Scotland
    Trim : dont know
    Engine : y20dth
    Default Changing the PGS16 diesel pump on a Y20DTH
    Hi,
    I have a Vectra C 2005 DTI with a dead diesel pump (twin plug PGS16) engine code is y20dth
    I have managed to source a complete working engine and pump, I also have the main ECU, Ignition key and Key reader from steering column from the donor car.
    My question is once I swap the pump over what other parts do I need to change to get the car running, from what I have read so far all I need to do is change the key reader on the steering column and I won’t have to re-program the pump, is this correct.
    Also are there any online articles covering the pump change and timing procedure? If not I can purchase a Haynes manual. I have access to the appropriate crank/cam locking tools and have plenty of mechanical experience. Just never worked on a Vectra diesel yet.
    Cheers.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    I did one of these just a couple of weeks ago. Just swapping the pump c/w PSG16 pump control unit is not the easiest way. If the PSG16 PCU is working (can explain how to test that if pump is still on car) the easiest way is to move the PCU to the new pump (need to cut and solder/sleeve some wires). It is just bolted onto the top of the pump and and has a rather delicate ribbon cable going down into the pump to a sensor which is retained by 2 T10 screws.
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Get the fault codes read from the dead pump.
    P1631 code ?
    Some thing official though to bear in mind. >>>>
    PSG16 (Twin plug pumps)
    This Bosch 44 terminal version contains a read/write 16bit flash memory in the PSG16 module.
    Where the engine management maps are stored. We do not encourage any user testing on these models.
    Other issues are that the headers are pump assigned which you cannot change or interchange between used pumps, spooling solenoids are the same as the PSG5 units and can be interchanged.
    May 2011
    South London
    Shame you bought all that engine etc as these guys do a lifetime warranty on pumps and program your old unit so its a straight re-fit £250.00
    http://www.ecutesting.com/catalogue/...edc010717.html
    Check this link warning its slow, its a ealier engine but the principles the same.
    http://vauxhall.workshop-manuals.com...ex.php?id=3358
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    Quote Originally Posted by C-Owner View Post
    P1631 code ?
    The bloke who wrote that text is the one who taught me almost everything that I know about VP44 pumps and PSG5/16 units. Very nice helpful chap (Peter Remmington of Auto-Tec, Kings Lynn) and saved me a lot of money. (I've tested and repaired both PSG5 and PSG16 pumps).
    Mar 2013
    Scotland
    Trim : dont know
    Engine : y20dth
    Hi guys, I would have responded sooner but was unaware I had replies, thanks for responding.
    OP-COM found the following codes, I read online that the P0149 means a dead pump.
    Read Info...
    Identifier: 0x0410
    VIN: W0L0ZCF6851068171
    Hardware number:1401
    Motor type: Y20DTH
    Part Number:55352865
    Software version number: VJAMS020_S
    Hardware manufacturer number: 0470504223
    Software Number: 1469946205C263_VB1
    Programming Date: FFFFFFFF
    Hardware key number: ÿÿÿÿÿÿÿÿÿÿ
    System description: BOSCH0100
    Type approval number: B02008
    Variant programming: 0x00004019
    Alpha code:
    Hardware manufacturer system name: PSG16
    ECU variant coding: 0x00007902
    Total number of fault codes: 4
    P0530 - A/C Pressure Sensor Circuit Low Input
    (03) - Present
    P0070 - Ambient Air Temperature Sensor Malfunction
    (71) - Not present
    P0149 - Injection Timing Control Circuit Malfunction
    (5B) - Present
    P0650 - <Unknown DTC>
    (04) - Not present
    Mar 2013
    Scotland
    Trim : dont know
    Engine : y20dth
    Quote Originally Posted by littleteapot View Post
    Hi,
    Yes the pump is still on the car, and I can use a soldering iron & heat shrink so would definitly be intrested in your suggestion.
    Mar 2013
    Scotland
    Trim : dont know
    Engine : y20dth
    Wish I came here sooner LOL
    I read elsewhere that these pumps cannot be repaired but this shows they can be, the main reason I purchased the whole engine with all the extras is because my car is an accident damadged repearable (very light damage), I don't have a pass/pin code for re-programing anything and to get that from vauxhall I need to be the registered keeper and show them the documents, I cannot get the documents till the car passes a vic check and it need to be running and able to move uunder its own power for the vic check.
    So I cannot get the code to program any replacment pump.
    woodbridge, suffolk
    278 Post(s)
    Trim : Design+
    Mileage : 101000
    Well, not all faults are repairable, sometimes replacement is the only option, or perhaps the cheaper option. Usually the failure is one of the following:
    1. Solenoids in the pump go short or open circuit. Sometimes this also causes (2). Peter can supply replacement solenoids for £70.
    2. Transistor in the control unit burns out. This is repairable and I've done this on a PSG5 pump.
    3. Mechanical failure in the pump 'core'. They can usually be repaired and auto-tec can do this.
    The one I did a couple of weeks ago I diagnosed as mechanical failure, but control unit was fine. Luckily Peter had a good secondhand pump which had a dead control unit and he sold me this for a very reasonable price. I removed the control unit from my dead pump, fitted it to the replacement pump and then refitted everything to the car, set the timing and reassembled. It ran perfectly! The whole job took me nearly 2 days and a trip to Kings Lynn with the dead pump (the spare Peter had was a different part number but turned out to be compatible).
    Correct diagnosis is the key to a cost-effective repair. If you were nearer to me I would help you with that, but alas you are not. I'll assume that you have verified fuel delivery to the pump (ideally use a hand-pump to force feed the injection pump and remove all air, etc. Fuel solenoid (between the injector pump outlet unions) can be tested in-situ, as can the control unit. Once these 3 items are ruled out, once can say with reasonable confidence that it is a mechanical failure.
    The test procedure is not easy to explain in writing, perhaps we can arrange a phone call when you are ready to go through the test process and I'll try to guide you through it!
    Hopefully we will find it is a mechanical fault and you can swap your PCU to the new base pump. If it turns out to be the control unit I can probably repair it for you by post.
    May 2011
    South London
    @littleteapot
    I keep a stock of the transistors if you need any
    @Kevin Marshall
    Its seems you have some time on your hands repairing this pump so check the bottom of the fuel filter housing for aluminium deposits (internal pump damage)
    if that's all ok and theres no damage to the pump go for a module swap.
  1. Help on changing deisal pump on vectra dti 2.0!!!!
    By ryanfoster in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2013, 17:00
  2. Y20DTH Diesel Pump
    By GMLes in forum Engine & Drivetrain
    Last Post: 7th November 2012, 14:37
  3. changing the fuel pump on my 2.0 dti!!! HELP!!
    Last Post: 16th October 2012, 22:58
  4. Y20DTH water pump
    By Pingu in forum Engine & Drivetrain
    Last Post: 20th July 2011, 11:03
  5. Y20DTH 2.0 Dti diesel fuel filter. Help needed.
    By 123rado in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2010, 21:27
replace diesel pump zafira a
vauxhall vectra injector pump removal
PSG16 VP44 Pump cam-crank internal sensors
vectra b Pump ecu repair
vauxhall zafira 2.0 dti fuel pump removal
vauxhall zafira 2.0 tdi changing module on diesel pump
vectra diesel pump repair
tools compatible to reprogram vp44 psg 16 injection pump
p0149 injection timing control circuit malfunction
psg16 no injector
opel psg 16 reprograming
pgs16 flash tech2
vauxhall zafira diesel pump removal
vectra y20dth fuel pump locking tool
p0149 psg16
can i use op com to write injection pump y20dth
opel zafira 2.0 dti 2005 code p0149
vauxhall zafira 2008 1.9 cdti deisal need car main code
y20dth diesel pump removal
opel pump ecu changevectra fuel pump ecu codingvauxhall vectra b injector pump removaly20dth injection pumpvauxhall vp44 removalvp44psg16 transistor
