Thread: shock absorber size query
    Regular Member Billy Mc's Avatar
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Engine : 1.9 cdti 16v
    Mileage : loads
    Default shock absorber size query
    hard to describe but here goes}
    basically had a snapped spring on rear ended up changing full set for apex 35mm drop .
    car is vec 1.9 cdti 16v sri springs are fitted correct way up
    and correct load for axles.
    problem is o/s/f is very stiff almost no bounce
    i did notice on removing springs on front there were 2 different spring sizes.
    i know the factory sri shocks are fine for these springs unsure about standard shocks
    could it be that in the past it has had a standard spring and shock fitted on o/s/f and would this be my problem of the shock bottoming out due to not enough travel.
    or anything else
    cheers guys
    Jul 2011
    UK
    Year : 06
    Sorry can't help but u got pic of thwarted car with springs on.
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Mileage : loads
    this is o/s/f gap between mid centre cap of wheel and arch is 13.5 inch
    other side is also 13.5 inch
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Mileage : loads
    a bit cleaner
    on standard springs
    lowered
    any more info/pics needed not a problem
    thank you
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Mileage : loads
    basically im asking are sri shocks different to standard. eg shorter.
    as i am puzzled as to why no bounce on o/s/f corner with new springs.
    n/s/f and rear are fine
    please see my op
    thanks in advance
    or could it be something ive overlooked
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Mileage : loads
    UPDATE solved worn front shocks replaced yesterday difference is night and day.
    VIP-Member Z80's Avatar
    Apr 2008
    Noumea
    14 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    Yes, SRI shocks are different, and should be used if lowering from standard suspension (or use aftermarket sports short travel shocks as well).
    northwest
    Default shocks...
    Quote Originally Posted by Billy Mc View Post
    hi....can you tell me how much you paid for your shocks and did you go to vauxhall...
    Jun 2012
    Bolton
    Vehicle : Vec C
    Trim : SRI
    Mileage : loads
    Euro car parts £110 for front set
  1. Shock Absorber desperation!!!!
    By smitd004 in forum Suspension, Wheels & Brakes
    Last Post: 23rd April 2011, 14:11
  2. 2.0t shock absorber help
    By stefan7153 in forum Engine & Drivetrain
    Last Post: 8th March 2011, 21:17
  3. Shock Absorber Help
    By Skinner in forum Suspension, Wheels & Brakes
    Last Post: 10th April 2010, 23:23
  4. shock absorber
    By Dwabo in forum Handling & Braking
    Last Post: 30th September 2007, 12:07
