Thread: Headlight switch lighting fault
    Mar 2013
    Castleford
    Vehicle : 1.9 TDi SRi
    Engine : 150bhp diesel
    Mileage : 65000
    Default Headlight switch lighting fault
    Hi
    One of the more niggly little faults on my recently purchased Vectra (08 plate 150 dti hatchback) is that the headlight switch doesnt illuminate.
    I have swapped the switch with a know working switch and mine illuminates in a friend's car, and his working switch doesnt light up in mine. This leads me tobelieve that the fault is with the wire that feeds the switch that powers the illumination of it. Does anyone know which wire out of the ones to the back of the switch powers the illumination bit. I presume if i get the correct wire i can piggy back from the same wire on a different switch, possibly the electric window switch in the drivers door ???
    Any help would be greatly appreciated
    Engine : 1.9 CDTi
    When doesnt it light as it only lights with the ignition on
    Mar 2013
    Castleford
    Mileage : 65000
    Quote Originally Posted by lee gsi View Post
    It doesnt light up at all when in my car
    Mar 2013
    Castleford
    Mileage : 65000
    But i should add that it is the only one switch that doesnt
    Regular Member Hue Jarse's Avatar
    May 2012
    Farnborough, Hampshire
    Engine : 1.8 VVT (Z18XER)
    Year : 09
    Quote Originally Posted by Shajennat View Post
    The main light switch illumination is the only one that isn't fed off the dimming signal.
    Check fuse 20 in the passenger compartment fusebox. (behind the end cover of the left hand end of the dash).
    This fuse also feeds the clutch switch, which would affect your cruise control, and ESP sensor where fitted.
    Mar 2013
    Castleford
    Mileage : 65000
    Quote Originally Posted by Hue Jarse View Post
    You are a Star...... The fuse had gone and I now have an illuminated switch and Cruise Control which was also not working. Is it just electrics you are a dab hand at as there are loads of faults with this car and any help is greatly appreciated
    May 2012
    Year : 09
    Well, I wouldn't describe myself as a 'dab hand' at anything in particular where cars are concerned, although my profession is electronics which does help in understanding car electrics.
    Whatever other problems you have though, it's worth asking on this forum as there's nearly always someone who knows what they're talking about, or has had the same problem before, who will come to your aid.
  1. Adaptive forward lighting fault
    By Sigmacca in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2016, 21:06
  2. drivers door lighting switch
    By beggsy in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2012, 21:27
  3. Adaptive forward lighting fault
    By Sigmacca in forum Vectra C / Signum Car Chat
    Last Post: 10th October 2011, 05:26
  4. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  5. New intelligent lighting fault handling
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2008, 19:36
vectra c lighting fault
vauxhall vectra c headlight switch does not work
vectra c headlight switch not illuminating lighting up
headlight switch does not work on my 07 plate vectra
vectra light switch not working
vectra headlight switch not working
