can you install front fogs on an insignia se i hear conflicting stories
More than likely you will need to replace the loom on your car as it wont have fog light plugs i had this problem with my vectra and the loom was £600 to retro fit properly so the lights come on the dash when there on etc. If the plugs are there you should be able to activate them by tech 2 at vauxhall. I got fog fitted on my insignia from the factory with the plus pack option.
has any one had this done tho. i want a price as i may go for a insig se or an 09 plate vectra c design.....................
the se insig the only thing it hasn`t got that i would want...
Apparently fitting fogs on an Insignia without them is quite a drawn-out job, from what i was told it's not even just a quick Tech 2 job either once fitted.
Not that easy... because you will need 2 trips to the dealer after you fitted them... as they need to send some codes to germany and get new back, to put in the car..
but happylightshow have made som wiring to help, with seperate module so you dont need a trip to the dealers..
