Thread: can you install front fogs on an insig se
    slough
    confused can you install front fogs on an insig se
    can you install front fogs on an insignia se i hear conflicting stories
    Oct 2006
    North Yorkshire
    Vehicle : Astra
    Trim : GTC VXR
    Engine : 2.0 Turbo Petrol
    Year : 2015
    Mileage : 3,200
    More than likely you will need to replace the loom on your car as it wont have fog light plugs i had this problem with my vectra and the loom was £600 to retro fit properly so the lights come on the dash when there on etc. If the plugs are there you should be able to activate them by tech 2 at vauxhall. I got fog fitted on my insignia from the factory with the plus pack option.
    slough
    has any one had this done tho. i want a price as i may go for a insig se or an 09 plate vectra c design.....................
    the se insig the only thing it hasn`t got that i would want...
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Apparently fitting fogs on an Insignia without them is quite a drawn-out job, from what i was told it's not even just a quick Tech 2 job either once fitted.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Not that easy... because you will need 2 trips to the dealer after you fitted them... as they need to send some codes to germany and get new back, to put in the car..
    but happylightshow have made som wiring to help, with seperate module so you dont need a trip to the dealers..
    Jun 2006
    Lake District
    Engine : CDTi 160
    Mileage : 53.000
    Quote Originally Posted by kenp View Post
    Yeah thats what it was! How long winded is that?? Sounds like overkill to me!
    I just fitted fogs to my girlfriends Rover 25 and all i needed was the fogs, switch and relay!
  1. Front fogs
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2010, 00:20
  2. insig query
    By kpf1grandprix in forum Insignia car chat
    Last Post: 12th October 2009, 18:50
  3. insig tyres
    Last Post: 29th September 2009, 11:39
  4. front fogs
    By derby4life in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2007, 09:55
