Results 1 to 10 of 24
Thread: Bonnet Problem
    Mar 2012
    Exeter
    Default Bonnet Problem
    Hi All,
    My bonnet lever was loose for a long time and I didn't know how to fix(I just read how2 but it s late) and unfortunately when I wanted to open bonet, lever came till the end with a noise at the front and now there is no tension at all and bonnet doesn t open!!!
    It's 2004 vectra so is there any chance to open it without break anything. I read nearly all the posts about that, still cannot open.
    First of all pull the lever and get someone etc. does not work.
    I thought to break the grill but when I look at the locking mech. area between the grill with a torch I cannot see the mech. because of some plastic cover around.
    I managed the take the bumper out to reach the locking mech. from down but there is another plastic-rubber protective and does not allow me to see anything.
    So any idea much appreciated
    Tekin
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    It's possible to get bar up between rads an move the bar to open bonnet that way.
    but would require access to ramps an I can tell you its not fun.
    only real way on drive is to unfortunately smash grille.
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Same as above. At first I thought the only way was to smash the grill, but can be done without smashing it.
    Full Member Z80's Avatar
    Apr 2008
    Noumea
    16 Post(s)
    Vehicle : Opel Vectra GTS
    Trim : Elegance
    Engine : 2.2 DTi 16V
    Mileage : 75 000
    It's a 2004 Vectra, so it's pre-facelift.
    I'll take some picture to help you figure out how it's organized underneath. ^^
    Regular Member DanBristol's Avatar
    Jan 2013
    bristol
    I had this problem the day I brought home the car .. not funny !!! I read alsorts on how bad it was etc etc, I pushed in the bottom grill so I could get my hand up with a big screwdriver and eventualy got it in the right spot and pop the bonnet opend, I didn't have any gaurds or covers on mine even though it an 04 too
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    sorry to hear your problem mate
    I spose its not as bad as having a facelift as you can get a 2nd hand grill on ebay for about £20 if you have to smash it
    Jan 2013
    bristol
    If you can get to seeing the bonnet pin poking through the top panel you will see the spring just push it aside to release the pin, there is some good pics on here somewhere I found really helpfull , took me about 20 mins
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    I have a pre face grille in my shed if you do end up smashing it
    Mar 2012
    Exeter
    Thanks for your all replies,
    I read all the comments, I found this pic. that I attached(if I could) is so clear but even though I took the bumper out and look through from underneath between rads. I cannot see this image all I saw is part hard part soft plastic-rubber, wish I took a pic. Only I noticed that when I press second lock releaser under the bonnet, and look from underneath I see that something pushing the black rubber towards me. I m not sure should I make a hole there with a long screwdriver if it is the center of the lock mech.
    I have rump but I couldn t use them because of this vectras are too low need extended parts or try after bumper out, without bumper it s like a truck. I just used 2 trolley jack and axle stands just in case. Finally I can t see this image in my car as if all around of the mech. surrounded with rubber.
    Mar 2012
    Exeter
    That's what i see between of rads. on the pic. Now it s dark and raining, car is on the ramp and I saw the wire pop out from its place trying to put it back with hook from underneath, cannot move the spring at all because I cannot see the center just touching the edge of V spring where the wire is pulling(I can see that point from underneath)
  1. Problem bonnet
    By andy 19cdti-sri in forum Vectra C / Signum Troubleshooting
    Last Post: 15th January 2013, 18:07
  2. Bonnet catch problem!!
    By ronnie63 in forum Bodywork & Interior
    Last Post: 13th January 2012, 22:49
  3. bonnet problem
    By wildtrout in forum Vectra C / Signum Troubleshooting
    Last Post: 14th September 2011, 16:24
  4. Another bonnet catch problem
    By Keithy in forum Bodywork & Interior
    Last Post: 27th September 2009, 15:38
  5. Bonnet release problem
    By Graeme in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2008, 23:58
