Results 1 to 10 of 14
Thread: Good Berks garage needed - suspect I'll break down tomorrow
    Jan 2010
    Berkshire
    Default Good Berks garage needed - suspect I'll break down tomorrow
    Good evening one and all - anyone know a reputable non VX garage in Berkshire - doesn't matter where or east Wiltshire I can have my car towed to if I break down tomorrow?
    Came off the M4 tonight and hit the A road and whenever I accelerated the car juddered.
    For the past year, it's been juddering intermittently in 6th when I've put my foot down at 2,000 rpm - it's like there's no power/acceleration and then suddently there it is, but with a jolt.
    Tonight it was like it in every gear under acceleration and every few seconds up the rev range - fine at a steady speed, but lumpy acceleration. No problem while revving in neutral.
    VX charged me £1400 for new DMF and clutch so praying it's not that, but suspect it might be. :-(
    Any ideas what else it could be if not the DMF?
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Are there any lights on the dash mate?
    I have op-com and am not that far from berkshire(im in basingstoke)
    Jan 2010
    Berkshire
    Well, I broke down this morning. Good news though! It wasn't the DMF
    I knew it wasn't as soon as I hit the motorway as it stopped just doing it under load and start doing it continually so I pulled off into the services where it became undriveable. The AA came out and said I had a misfire. I thought "that will be cylinder number 3 then". He plugged in the machine and voila - P0203 - injection circuit no. 3. He removed the plug, which was dirty, cleaned it and tightened the connection bits, which seems to have fixed it for the time being. He's put it as a temporary repair so I need to get it done properly.
    So - who's done the wiring mod to cylinder 3, how easy/difficult is it and how much should it cost?
    Cheers!
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    Its about £17 IIRC and it comes in a kit with the plug and wires.
    Just need to cut the 2 original wires and solder the new ones together onto the old ones.
    Jan 2010
    Berkshire
    Iis it just vauxhall that sells this and had this problem or do fiat and Alfa also have this kit and mod? Phone VX and they wanted £50/£60 for the kit and £192 labour. The thieving tykes! I should be covered by my AA repair cover so it should only cost me £35 to have someone else do it for me, but VX are fully booked to 4th April - obviosuly busy robbing people some I'm wondering whether to go to Alfa or any other garage in the Bracknell area.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Its a very simple job:
    http://www.vectra-c.com/forum/showth...njector-wiring
    The Kit shoudl be less than £20 unless something drastic has changed since I did one about 3 months ago.
    Regular Member happypostie's Avatar
    Slough
    130 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    this is the thread on it , if that helps , dean ( plasma) did mine , the kit cost around 14 pounds from vx using the trade card , and took dean around 20 mins to do ,as he wanted to tie it all into the loom ,
    http://www.vectra-c.com/forum/showth...g-Mod-DONE-and
    Jan 2010
    Berkshire
    Thanks guys - I'll do it myself then! Just need the part - guy I spoke to at VX didn't have a clue what he was talking about. Cheers ta!
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Giw View Post
    Use the part number from the link I linked you to mate.
    Jan 2010
    Berkshire
    Picked the part up this afternoon - caused some confusion first as the no. in the article is not the same as the number in the photo so I was originally asking for a battery for a Vauxhall Astra! When I realised the mistake it cost me £11.80 with my masterfit 25% discount so that will be a job for the weekend. Cheers for the help as per usual!
  1. Replies: 13
    Last Post: 25th March 2011, 12:45
  2. Decent garage in berks? - suspected DMF
    By Giw in forum Engine & Drivetrain
    Last Post: 4th June 2010, 21:47
  3. Suspect DMF..Advice Needed
    By rollercoaster63 in forum Diesel Engine related
    Last Post: 21st March 2010, 12:06
  4. Good Trusty Mechanic/Garage Needed
    By darrynwarner in forum West Midlands
    Last Post: 7th July 2009, 23:44
  5. Prison Break is pretty good actually
    By Leviathan in forum The 'Off Topic' room
    Last Post: 20th May 2008, 23:47
