Results 1 to 10 of 19
Thread: cold starting problem ???
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    Default cold starting problem ???
    as above , i turn the key the car fires into life with a ploom of smoke and feels like it is running on 3 cylinders for about a min then it's fine,
    no faults recorded,
    no spanner light coming on,
    it just runs like a bag of spanners for no more that 60 seconds then it's all good.....
    and it only does this from a propper cold start not once it's been run for a while then left a few hrs but only from an over night park up !!!!
    any ideas ??
    Midlands Mod Shop - NFFC.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    What engine you got mate?
    Trim : Get a
    sorry my bad, it's a remapped 8v 120 cdti 2005 and it's only happened for the last week or so...
    Carnoustie
    glow plugs would be the first port of call
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds like failing glow plugs. Also, does your temp gauge move up to 86 degrees when driving?
    Trim : Get a
    Quote Originally Posted by ronnie63 View Post
    Quote Originally Posted by tony-1977 View Post
    had new glow plugs not so long ago and yes temp gauge moves up to correct temp after 5 mins or so of running, i am sure i have read somewhere about the possibility of an injector wiring fault like the 150 has but
    Carnoustie
    I would still check them before ruling them out, it's simple to do
    Ronnie
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Also, cycle the glow plugs a couple of times (ignition on for 5 seconds, off, on for 5 secs, off, on for 5 secs, start engine).
    If it starts ok this way, be best replacing the glow plugs
    Trim : Get a
    Ronnie
    will get my old mans tester or is there anything on moc-po i can test them with ???
    may just try this, thats another £50.00 needed if it is them, the last ones cant be anything more that 6-7 months old either and they are genuine vx ones too
    Regular Member phil67's Avatar
    Nottinghamshire
    Vehicle : Vauxhall
    Trim : Exclusive
    Engine : 1.8
    It's sulking because you have brought that new corsa matey lol
  1. Cold starting problem continues!! Need Help!
    By Gworld247 in forum Engine & Drivetrain
    Last Post: 27th March 2013, 18:27
  2. Starting problem with z19dt engine from cold.
    By 123rado in forum Engine & Drivetrain
    Last Post: 20th February 2012, 23:15
  3. cold starting problem
    By iansfocus in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd February 2011, 16:54
  4. Starting in the cold
    By Rebellion8878 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 22:15
