Thread: Tech 2 help please
    Regular Member coooky's Avatar
    May 2011
    washington
    Default Tech 2 help please
    Has anyone got a Tech 2 that could reprogramme my car as i have been told the system could be corrupt
    inbox me with a price if you can help me thankyou
    crook
    What do you mean by corrupt ?
    May 2011
    washington
    the auto electrician i spoke to said it might need a reprogramme because when i jump started the car it could have put a fault into the system
    crook
    Have you checked to see if any faults are on it ?( op com or pedal test or fault code reader)
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    A jump start won't corrupt your system fella it might spike a ecu but if the car starts and drives as normal then can't see a need to reprogram it
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    I don't know where you are in the country - but @plasma is our resident Tech II Trader
    Middlesex
    Trim : SRI
    Mileage : 100k
    p.s. - whats the symptoms of the car. Why do you think there is an issue. Error codes etc?
    Administrator plasma's Avatar
    On the Forum
    538 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by coooky View Post
    Lets start at the beginning what issues are you CURRENTLY having with the car so make you think its corrupt? (although this very highly unlikely)
    May 2011
    washington
    if i start the car and only drive a shop trip then park it up and leave it it needs jump starting
    the fan kicks straight in on start up,the glow lights take around a min to go out it used to be around 5 seconds the car at stand still the engine jumps all over (could be the inlet manifold) and if i try and go over 4k revs it starts juddering
    fault code p0115 had 2 sensors changed and still the same one garage said the car was saying the temp was -65
    On the Forum
    538 Post(s)
    Engine : 150
    Mileage : 74000
    if it needs jump starting every time you either have a dead battery or dead alternator normally (or a blown fuse in the charging circuit?)
    For the fan to kick in start at startup it will do this if it cant sense what the engine temperature is, it does it as a saftey precaution to cool it rather than not to cool it, which also explain why the glow plugs are on soon long (probably not a minute though). The juddering could be because its running the engine mapping and fuel for a car thats very very could and could be overfuelling it... So it looks like you need to find out why the engine temp is reading soo low as one thing and if the battery or alternator is goosed as the 2nd thing..
  1. Tech 2 / Op Com
    By stephen_brady in forum Electrical & ICE (including SatNav)
    Last Post: 29th January 2012, 17:05
  2. Tech 2 help
    By bish in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:35
  3. tech 32 ?
    By les287 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2011, 21:04
  4. tech 2
    By jamesworts in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 08:17
  5. tech 2
    By neill in forum General Chat
    Last Post: 4th April 2011, 15:33
