Results 1 to 10 of 16
Thread: Auto electrician needed (Tyne and Wear)
    Regular Member coooky's Avatar
    May 2011
    washington
    Default Auto electrician needed (Tyne and Wear)
    Hi guys can you recommend a auto electrician in tyne and wear phoned 2 and they cant help
    just been told i might need a tech 2 reprogramme can anyone help in the northeast ??
    Regular Member biffbangpow's Avatar
    Jul 2012
    ferryhill
    Vehicle : vectra
    Trim : gsi
    Engine : 3.2
    Year : 02
    Mileage : 96k
    whats needed like
    May 2011
    washington
    to start with the car was showing an error in the temp sensor and that was changed the error was still showing after the sensor was changed twice
    i was speaking to an auto electrician on the phone today and he said i should try a tech 2 incase the system has an error in it
    he said that when i changed the temp sensor and then had to jump start the car it could have put an error in the car
    he also said try taking both the battery leads off and holding them together for 15 seconds to see if that would clear the error
    Full Member lizard's Avatar
    Oct 2006
    southampton
    16 Post(s)
    he also said try taking both the battery leads off and holding them together for 15 seconds to see if that would clear the error[/QUOTE]
    Never heard that one matey....
    May 2011
    washington
    he said it would shock the system possibly deleting the errors if there were any there ???
    Regular Member simon7257's Avatar
    reading
    Touching the leads together is brilliant it's called a battery reset and clears faults by removing static charge from the system, started my car one morning just about to head off on holiday and my whole dash was dead, switched her off quick battery reset and problem solved never happened again, just be careful the vehicle you do it on doesn't have a second battery anywhere eg Mercedes
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have you got a volt meter?
    what trouble code was set for sensor?
    May 2011
    washington
    no volt meter but i could get the loan of one
    the code was p0115
    a garage did have a look at it but there were not that good for electrics they did say the car was saying the temp was minus 65 degreees thats why the glow plug light was taking so long to go out
    reading
    P0115 Engine Coolant Temperature Circuit Malfunction
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    If you can loan one you can do some checks yourself with multimeter an paper clip.
    all you need check is disconnect an check you have a 5v reference and check the earth is good.
    plug back in. And probe back of connector with paper clip.
    then observe voltage on starting an as the engine warms up.
    cold engine is around 4.5v an hot engine around 0.5-1v
    if its reading -65 even after to sensors
    you may have a short to ground on control wire
  1. Remapping ecu in tyne and wear??
    By SlowCoach in forum Tuning
    Last Post: 6th October 2012, 21:35
  2. Tech 2 Auto electrician needed Tyne and Wear or County Durham.
    By Martinlw in forum Electrical & ICE (including SatNav)
    Last Post: 20th July 2011, 19:12
  3. OpCom in tyne and wear
    By coooky in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2011, 19:46
  4. Auto Electrician Leigh / Manchester Needed
    By Hursty103 in forum North West (RO - bonehead, ARO Woody
    Last Post: 22nd February 2011, 09:35
