Thread: Retro Fitting Park Pilot Rear Only - 2005 Facelift Elite
    Jun 2007
    Kidderminster, West Midlands
    Vehicle : Vauxhall Vectra
    Engine : Z30DT
    Mileage : 65905
    Default Retro Fitting Park Pilot Rear Only - 2005 Facelift Elite
    Hello Guys,
    I'm in the process of buying a bumper & full park pilot kit off a member on here.
    I now need either advice or someone to help me retro fit this to my car!
    I have a 2005 (55) Facelift Elite.
    Where do i start?
    I've looked through 13 pages of how 2's with no real help.
    Anything would be a great start?
    Many thanks,
    Glenn.
    Regular Member squirrell25's Avatar
    Jan 2010
    wednesbury
    Vehicle : SIGNUM 2.0T
    Trim : WAS DESIGN
    Engine : Z20NET
    Mileage : 99.000
    have you checked to see if your car is pre wired for park pilot
    if it is you should have a white plug next to the black towbar plug in the spare wheel well and the plug for the control box is behind the fuse box in the boot and the speaker plug is taped up on the back of the roof lining around the passenger side b piller
    if it prewired it is easy it all just plugs in and with a little programing it should all work fine
    if it not prewired you need a loom makking andy.l is your man for that he makes a lot of looms for members and he is cheap
    i assume you will be swaping the bumper over if not you will need to take of the mounts and stick them to your own bumper
    if you need any help let me know i only live in wednesbury
    Jun 2007
    Engine : Z30DT
    Mileage : 65905
    @squirrell25 Can you show me any pictures of what i should look for when i get back? How do i remove the black on the dash to see if anything is there also?
    Any help would be great.
    Thank you mate.
    Jan 2010
    wednesbury
    Trim : WAS DESIGN
    Engine : Z20NET
    Mileage : 99.000
    the switch in the dash is only for the front sensors iirc
    the easy plug to look for will be the one that goes to the rear bumper if you lift the boot carpet look to left hand side of the wheel well below the plastic trimthat covers the boot latch you should see two plugs 1 black (towbar) and 1 white (park pilot) next to the earth point
    if the white plug is there you should have the one for the control box
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Trim : Irmscher Elite
    Engine : 3.0 CDTI
    The switch is for the full kit, but it should come on automatically when you select reverse but it initiates the front sensors too. if you want to turn the fronts on without selecting reverse then you can press the button. I haven't come across a vec yet that didn't have the rear sensor loom installed.
    Check out my previous recent threads, there's a lot of VERY useful info/ photos/ links from other members on them. Should help you out
    Jan 2010
    wednesbury
    Trim : WAS DESIGN
    Engine : Z20NET
    Mileage : 99.000
    Post
    Quote Originally Posted by BigWilko View Post
    my old 52 plate elite vectra did'nt mind you it did'nt have leather trim or electric rear windows either
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    What kit are you buying?
    the original fitted? or the VX aftermarked kit.... as the wiring, plugs ect. is different... only the coding is the same...
    Sep 2012
    London
    Engine : Z28NET
    Have a word with Andy.L on here. He can offer some great guidance.
    Timisoara, Romania
    10 Post(s)
    Trim : Estate
    Engine : Z19DT
    Mileage : 210.000
    hi guys,
    I was just looking through TIS for the park pilot wiring diagrams and came across this:
    "Note: As of model year 2005, the Park Pilot loudspeaker is incorporated into the column integration module (CIM module) and is no longer available as an individual part."
    So, I guess there is no need to install any speaker for the rear park pilot.
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    Yes you do... As the one in the cim is for front....
  1. advice needed to complete retro fit of front park pilot
    By driver9524 in forum Electrical & ICE (including SatNav)
    Last Post: 27th October 2012, 10:00
  2. Park Pilot Vectra 2005 pre facelift
    By justathome in forum Electrical & ICE (including SatNav)
    Last Post: 9th July 2010, 15:38
  3. Rear Park Pilot
    By war222 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2010, 14:15
  4. Park Pilot Speaker fitting
    By tramman in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2009, 00:29
  5. latest update on retro fitting parking pilot
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 15:35
