Thread: Vectra c est CDTI150
    Feb 2013
    buckley
    Vehicle : vectra cdti 150 est
    Trim : design
    Engine : 1.9
    Default Vectra c est CDTI150
    No power under 2000 rpm.replaced: EGR,full service,regen on DPF,new MAP and MAF,injector number 3 repair,but still no or very little power under 2000rpm??? Anymore ideas?please
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Engine : 1.9 cdti 150
    Mileage : 119k
    Have you checked and replaced the boost vacuum pipes at the front right of the engine?
    Feb 2012
    sheffield
    Vehicle : SIGNUM 1.9 CDTI ELITE
    Trim : ALL OPTIONS ELITE
    Engine : 1.9 CDTI 150
    Mileage : 140,000
    remove and clean throttle body and whilst its off clean the recess it fit onto.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Have you checked boost solenoid and pipe work?
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    What they said is the most common cause next to EGR.
    After that maybe the O2 sensor, they cause a simular fault but usually give a fault code.
    Feb 2013
    buckley
    Trim : design
    Engine : 1.9
    I've cleaned egr and throttle body and the manifold.vac tested pipes and pressure tested inter cooler and boost pipes.no faults stored,and everything is workin as is should on the live data on me scanner.ive fixed a couple of these problem on customers cars.but can't fix my own!!
    Feb 2012
    sheffield
    Mileage : 140,000
    Have you checked the swirl bar is working as it should?
    Feb 2012
    sheffield
    Mileage : 140,000
    tried unplugging the EGR and taking it for a run?
  1. Vectra Elite CDTI150
    By Matt_Bankier in forum Vehicle Diaries
    Last Post: 17th September 2013, 23:03
  2. Vectra 1.9 cdti150 ECU location...
    By toadie83 in forum Engine & Drivetrain
    Last Post: 10th January 2012, 14:59
  3. Vectra CDTI150 ECU Remapping
    By ShaunsVectra in forum Diesel Engine related
    Last Post: 21st January 2010, 17:10
  4. J** OGY vectra cdti150 sri black
    By vectra666 in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 19th January 2009, 22:10
  5. 205hp from CDTi150
    By POAH in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2006, 13:57
