Thread: Few small problems can you help?
    Aug 2012
    hampshire
    Default Few small problems can you help?
    Hello My 1.9ctdi 150 144k fvsh was running perfect for months after I bought it, now a few things have happened.
    1. Takes longer to start ( about 10 more secs of turning over) , the other day it ran lumpy and wouldn't rev right for a few secs then puff of black smoke comes out and then cleared and ran fine.
    2. Cleaned egr and boost sensor, with the boost sensor there was a really small bit of plastic that broke off when I cleaned the crap out (could this affect anything) it's not the main bit of the sensor but a thin straight bit next to it (hopefully that makes sense)
    3. Just had flywheel/clutch replaced from local garage and after driving 40miles when waiting at lights with heaters on I can smell gear oil, think its burning like its on the exhaust or something but could but the smell of it but not burning.
    anyone with any ideas would great to hear from you
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    the bit that broke off you boost sensor is needed so i would suggest buying a new one.Euro car parts are doing 25% off all parts at the moment so IIRC its about £35 for a new 1 which isnt bad
    Jan 2012
    Silverstone village
    If its taking longer to start then it may be;
    1) Glow plugs , will be more noticeable on cold starts and you would have a spanner icon on the dash until it warms up.
    2) Battery, may not be getting fully charged (lots of short journeys?) or may just be on its last legs the cold weather again will pull out weak batteries, and the car will tend to crnk either slower or will die sooner.
    3) Starter motor may be on its way out if the other two are ok
    North West - Assistant RO Woody's Avatar
    May 2012
    North West (Warrington)
    234 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    Quote Originally Posted by justin32 View Post
    So are Vauxhall via their Masterfit Member scheme. Enrol and get a £40 voucher for free to use against anything you want, plus, if your dealer has entered into the true spirit of the scheme, you will also get 25% discount off parts (and or service).
    Just for info, so check it out before you part with your money elsewhere fella.
    Woody
    Aug 2012
    hampshire
    Thanks for all the fast replys guys. Gonna sort the boost sensor and check plugs/battery then report back.
    Aug 2012
    hampshire
    thanks for the heads up about joining masterfit, i got that part for £15 and its a glow plug that needs replacing.
  1. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 12th November 2019, 09:21
  2. A few small problems....
    By PowPow in forum Suspension, Wheels & Brakes
    Last Post: 5th June 2012, 16:34
  3. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  4. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
