Results 1 to 2 of 2
Thread: fault code 1483 Fan Control 3 Open Circuit
    newport
    Default fault code 1483 Fan Control 3 Open Circuit
    has anyone found a cure for this fault code?
    ours is very intermitant, can come on once every couple of days, or go weeks at a time without coming on, usualy comes on when hitting a bump in the road, and only stays on for a couple of seconds.
    both vectras i have had have done this, always in the winter, in the damp cold weather, and never in the summer, so assuming this one is going to be the same as the weather warms up.
    ive done loads of searches on the internet and am yet to find a cure for this? seems to be a moisture/bad conection/wiring issue, but where do i start?
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Pretty sure that was the one I had when the fan control unit gave up, resulting in no fan at all. Only revealled itself in a traffic jam - being winter that was the only chance it had to get hot.........
  1. P0650 mil control circuit malfunction code
    By bobsimes in forum Vectra C / Signum Troubleshooting
    Last Post: 15th May 2018, 14:41
  2. P1482-04 fan control 2 circuit open
    By mack in forum Engine & Drivetrain
    Last Post: 28th March 2014, 17:54
  3. Replies: 11
    Last Post: 26th June 2011, 19:29
  4. Fault Code P 1483
    By charliedub1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th June 2011, 22:46
  5. fault code 1483 and 1482
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2011, 13:53
vectra 1.8 fan control
Vaughan fault code 1483
