Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Turbo build
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Default Turbo build
    Thought i'd start a new thread on my Edition 100 turbo rebuild.
    A bit of history first. last year I started loosing power so I replaced both solenoid boost valves to no avail. Soon after it went downhill sharply, first it would smell of oil then it would almost cut out when setting off from standstill. I took off the inlet pipe to the turbo and found oil so I cleaned it all up including all hoses and intercooler. Following the route of the hoses I thought the Vacum pump was leaking and drawing oil through the hose in to the inlet so I replaced it. I was wrong, it was still drinking oil. Following the sugestion of a faulty turbo, I had a look and found it to be fubard. I took it off and it looked like this
    New turbo needed, I decided to follow CavemanNige and fit the TD04 with it modified to the bigger 16T. New turbo ordered and planned on sending it off to a turbo specialist to carry out the hybriding but was advised not to by Nik at Neo Brothers as he said the company wouldnt modify it to the same spec as his to match his software. Was told better off leaving the turbo as standard and going for the stage 5. Should be looking at around 250bhp. Noice.
    History lesson over. This week I have fitted the turbo and prepared as much as I can ready for the new water lines, downpipe and injectors. A mention to Cavemannige here, I sent him off my injector loom to modify to fit the 630 Injectors which he did then, got told by Nik they wouldnt be needed. I would only need the green injectors. So, I asked Nige to put it back to normal. Big thankyou and sorry Nige .
    As I was lowering down the downpipe, the lower Lambda sensor got caught and nipped off the end GUTTED. Niks sending hopefully a correct replacement.
    All remaining parts should arrive by the weekend.
    Jim
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    More parts have arrived incl. Water-oil lines, green injectors, lambda sensor, Ferrita downpipe and Maptuner.
    First I checked the lambda and found its the wrong one. The downpipe is different as mine is joined directly under the cat where as with the Ferrita, its joint is past the flexi. So, I now need to get booked into Powerflow to get this sorted. This meant me refiting the old cat to get it there.
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Now have another pair of lambda sensors coming.
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    All oil and water lines are now on. Just need the injector loom and lambda sensor to turn up.
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Final parts arrived today so i got them fitted. Loaded up the maptuner and plugged it but didnt load the new map on. By this time it was pretty dark so i tidied away the tools and ill have a look tomorow
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Engine : 1.6T SIDI Petrol
    Lol butt clenching time is coming...... Good job bud, stick with it...
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    Thanks for the loom nige, the blue tape made me instantly want blue silicon hoses to match lol. Guted really because its sorned so cant go anywhere in it ti lll the 1st and we go to our first car show this year. Scarry time to test drive.
    South Central England
    18 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    What size compressor are you using now?
    Dec 2005
    Stone, Staffs
    Trim : Edition 100
    Engine : 2.0T
    The td04l-14t
    Jun 2009
    South Coast
    12 Post(s)
    Vehicle : Insignia
    Quote Originally Posted by nutron View Post
    same size as that one you looked at on the shelf in my garage mate..
  1. Turbo re-build costs...
    By John LE in forum Diesel Engine related
    Last Post: 7th March 2011, 10:12
  2. Oil build up questions.
    By Mogsy007 in forum Diesel Engine related
    Last Post: 28th February 2010, 10:44
  3. Buy Vs build a PC?
    By wardy in forum General Chat
    Last Post: 13th September 2008, 19:38
  4. The Build of my install
    By Durk in forum Quick Photo Album
    Last Post: 24th March 2008, 19:15
  5. My boot build
    By Darrell in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2007, 07:51
