Thread: Fuel Filter Meant To Be Black?
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default Fuel Filter Meant To Be Black?
    Just changed the fuel filter on my 1.9cdti, has got 90k on the clock and the old filter was jet black, blacker than my engine cover!
    When I pulled it out, it was like a cup of diesel as all the crud was holding the diesel and preventing it from leaking through the filter element!
    Do you think it has ever been changed in the cars 90k life?
    I just wonder as the one in the How2 was only slightly brown and hadn't been done for 30 odd thousand miles if I remember rightly!
    Filter housing was really welded into the crash box too, took a bit of wd40 and wiggling to get it out!
    Wirral
    5 Post(s)
    Engine : 1.9CDTi
    Mileage : Lots
    No, that's one knackered filter! At least you're all sorted.
    crook
    Aye..... Well knackered that like.
    should run better now
    i usually change mine twice a year
    Mar 2011
    Wirral
    Going to start changing it everytime I service it now. Been putting it off as all I read is it's a pig to change but it wasn't that bad!
    Ahh well, oil and all other filters next weekend!
    Regular Member Learch's Avatar
    Jan 2013
    Chester
    Vehicle : Vectra c
    Trim : LS
    Engine : Cdti 8v
    Mine was like green sludge when I took mine out, it looked like it had done the majority of the 130k, ran loads better straight away. Gonna keep on top of mine and do it a couple of times a year aswel.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Mine was like that too. When changed, the motor ran 100% better, and used less diesel too
    Hanging Heaton
    24 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    How much are GM filters from vauxhall?
    Quote Originally Posted by leemarksmith View Post
    Anywhere between 10 and 20 squid. The 1.9 can be a ***** to change due to the screw-on top and the crash box, but at least it operates on positive pressure. The 3.0 is a piece of cake to change with the screw holding it all together but selling it so it doesn't get any air in through the seal with the suction pressure can be a nightmare...
    Hanging Heaton
    24 Post(s)
    Mileage : 140k
    I've got a 3 legged filter tool so should be ok, gonna pick up a few fuel clips while at it, just in case lol
    Take a look at the receipts and check the Fuel Filter is listed
    Check the OE Service Schedule, but from memory it can be every second service depending on mileage which could be up to 40K miles for some cars
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
  3. Hoe does the fuel filter come off
    Last Post: 22nd June 2009, 14:51
  4. Fuel filter on a 3.2
    By fuzzbomUK in forum Vectra C / Signum Car Chat
    Last Post: 16th March 2009, 10:27
  5. Oil Filter location and Fuel Filter
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 26th July 2006, 10:31
