Results 1 to 10 of 16
Thread: mas performance remap and egr query
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Engine : 1.9 cdti 150
    Mileage : 119k
    Default mas performance remap and egr query
    Im running a mas performance remap with supposed EGR and DPF deletion.
    My EGR is also blanked.
    I recently unplugged my EGR electrical connection on advice from another forum member to try and fix my sluggishpulling away problems.
    With the electrical connector unplugged, the car does feel a bit better. However, the engine management light has now come on.
    Is this correct, evwn though the EGR has supposedly been disable or have MAS been telling me porkies?.
    Jun 2006
    St. Helens,Merseyside
    iirc its not a delete but they move/change the ecu request figures so it doesnt open
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    The EGR signal is set to 100% closed all the time on a remap.
    Feb 2013
    A Higher Level
    Vehicle : VECTRA C
    Trim : YES
    Engine : 1.9 CDTI
    just because its closed in the map does not mean you can unplug it.
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Okay thanks guys. Plugged it back in.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    276 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    There is a problem with some of the EDC16C9 software versions - when EGR is disabled in mapping using the 'normal' method, the engine fails to produce boost below 2000rpm. The strange thing is that these cars perform well immediately after flashing the ECU via the OBD port, but after a few 10's-100's of miles they develop this lag problem.
    As yet I've failed to find a solution I have some ideas, but unfortunately I've not had the opportunity yet to study one of these 'problem' ecu's properly and find the solution. I really need a guinea pig
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    My car has had the sluggishness under 2k rpm even before I had the egr disabled.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by chrislloydie View Post
    Is your inlet fully functional? I.E your swirl bar hasnt fallen off the swirl tops?
    Also - have you cleaned out your PCR Valve at all lately - could be an issue also.
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    where is the PCR valve on the cdti?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by leemarksmith View Post
    Its the black valve that sits on the top of the RAD and has the vacume hoses going from that to the turbo etc
  1. MAS Performance Remap
    By amand in forum Diesel Engine related
    Last Post: 29th April 2012, 13:08
  2. MAS Performance remap DONE!
    By unikarl in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2012, 15:59
  3. mas performance remap
    By fjaimo10 in forum Diesel Engine related
    Last Post: 30th November 2011, 11:43
  4. Remap by Mas performance?
    By gumanue in forum Vectra C / Signum Car Chat
    Last Post: 6th May 2010, 20:26
  5. MAS Performance remap
    By hideyspidey in forum Diesel Engine related
    Last Post: 29th July 2009, 13:30
