Thread: Reset Radio
    May 2012
    Great Torrington
    Default Reset Radio
    After fitting a new battery , have lost radio , now radio will not switch on /off to input code this happened before , I found a thread how to reset , is there anybody out there that knows how to do it , please , no radio will drive me nuts
    crook
    What model stereo ?
    May 2012
    Great Torrington
    CDR 2005 . DID IT ONCE BEFORE WHEN NEW BATTERY FITTED ,BUT CANT REMEMBER HOW
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Turn it off, press and hold the AS button, while holding it turn it back on. It should beep and allow you to enter the code.
    May 2012
    Great Torrington
    cant switch on/off
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Not even with the ignition key??
    VXR where are you now
    16 Post(s)
    Vehicle : Nissan GT-R R35 Vectra XP2 CDTI
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    Year : 2010
    If it won't switch on or off have you checked the fuses
    May 2012
    Great Torrington
    Radio /cd works but will not switch on or off with radio on /off button
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Quote Originally Posted by scrivy View Post
    I found the quote below on HonestJohn.co.uk - will admit it's a long shot but it might work? Worth a try though as the original problem sounds very similar to yours mate.
    Quote Originally Posted by Dynamic Dave on HonestJohn.co.uk
    You could try and see if the stereo will reset itself by disconnecting the power to it. Either pull the fuse in the fuse box, or disconnect the battery for a few seconds. This is of course providing you have the security code to hand.
    Another thing to try is to override the ignition on/off command to the stereo. With the stereo off, turn the ignition on until you get the dash check lights, then press and hold in buttons 1 & 3 on the stereo and finally press the on button. Once the stereo beeps and the display says either Igition on or off, release buttons 1 & 3.
    The original link is here: http://www.honestjohn.co.uk/forum/po...ex.htm?t=25511
    May 2012
    Great Torrington
    Many thanks ,new battery should be here tomorrow , so will try
  1. Central Dashboard Display & Radio cut out / reset problem: 2004 Vectra 1.8
    By mikethemechanic in forum Electrical & ICE (including SatNav)
    Last Post: 23rd January 2021, 21:16
  2. Radio-clock-reset
    By Jabbekot in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2010, 13:03
  3. EML reset
    By paul_sri150 in forum Engine & Drivetrain
    Last Post: 15th May 2010, 14:15
  4. ecu reset
    By km101 in forum Electrical & ICE (including SatNav)
    Last Post: 9th February 2007, 13:04
2004 vauxhall signum stereo code
reset radia opel Vectra c
restart cd 2005 opel vectra c
reset radio code vectra c
radio vectra please reset
opel vectra b wheel radio command reset
reset radia z opla vectry c
jak zresetowac radio z opla vectry c
Opel vectra Radio reset
radio wont turn on vectra c site:www.vectra-c.com
