Thread: Fuel Filter Leak ;( Help!
    Regular Member Black_Shadow's Avatar
    Feb 2013
    Cwmbran
    Vehicle : Vectra c
    Trim : C
    Engine : 1.9dt
    Default Fuel Filter Leak ;( Help!
    Welcome.Sorry for my english but i;m from Poland I have a problem with the fuel filter z19DT. I unfortunately leaked. It looks like that from the place of the large nut on top of the fuel filter. In addition, when the car is cold for a long time before firing;/ turns out there is a gasket that I can change? I have one question for anyone who knows places to wear a fuel valve is not stepping back? The wire on top of the filter or the outgoing side of the filter?
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    Is the leak between the cup and the top of the filter? The rubber between can twist a litle if the gasget is dry when the top is placed back on after a filter change. Try take of the top, set a tiny amount of grease on the rubber gasget and turn it back on.
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    The filter rubber should be wet with Diesel before you put it on and torque up the lid.
    Feb 2013
    Cwmbran
    Vehicle : Vectra c
    Trim : C
    Engine : 1.9dt
    but fillter was be changed 6 months ago ;/ so why yesterday started leaked? before i dont see any leaks by there. you maybe now how and where fit a non return fuel valve?
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by Black_Shadow View Post
    Defo leaking from the top of the black canister?
    I think you have to remove it - inspect, replace the filter with new seal and see how you go. CHeck the canister for cracks and make sure the two fuel lines are cliped in correctly.
    Feb 2013
    Cwmbran
    Vehicle : Vectra c
    Trim : C
    Engine : 1.9dt
    Quote Originally Posted by AntSSSS View Post
    Yes. Today i order at e-bay new filter and seal se at saturday i try replace it whether it can cause long start the car after long standstill?
  1. 1.9cdti fuel filter housing leak ?
    By john1 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 18:41
  2. Replies: 19
    Last Post: 30th May 2012, 15:53
  3. Fuel filter housing leak any suggestions?
    By Toe-side in forum Engine & Drivetrain
    Last Post: 11th March 2012, 12:00
  4. Fuel leak from filter housing
    By tom_nw in forum Vectra C / Signum Troubleshooting
    Last Post: 5th December 2010, 23:27
  5. How do i remove the fuel lines from 3.2 fuel filter...?
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2010, 23:07
