Thread: Heater blowers not working
    Mar 2013
    Swansea
    Vehicle : Vectra 2.2ltr
    Trim : Walnut
    Engine : 2.2ltr
    Year : 03
    Default Heater blowers not working
    Hi guys, I came home a while ago to find the blowers wouldn't knock off so had to take the fuse out. Anyway, took it to the garage, found its quite common, the scuttle tray flooded and went through into the passenger side blowing the heater resistor, they went to get the part from vauxhall, they wanted something silly like £140, the garage then told me I could get it on eBay, which I've done for a couple of quid.
    So I have the heater resistor and looked through the forum to see how to fit it, but I must have followed a different vectras instructions when I removed the glove box I can't for love nor money find the heater resistor. Any ideas anyone? Or any idea how much it would roughly be to fit in a garage?
    Any help would do cheers
    I have a vectra c elite 2.2ltr petrol 03 plate btw
    Midsomer Norton
    Vehicle : Vectra C 2.2 DTi Elite
    Hi there, I had the same with mine (Vectra C 2.2 DTi elite) but the water got in and both the control board and fan then failed. Did you smell burning when you last operated it? I finished up having to bite the bullet and got a new fan and control board intalled by the Vauxhall dealer - cost £600. At least now I have a guarantee!
    Sep 2012
    Stoke on Trent
    Engine : 1.9 CDTi 150 Z19DTH
    Hi. There are two different types of resistors. Cheap one for cars without ECC (4 Speed Manual heater control)
    and an Expensive one for cars with ECC (7 speed auto heater control)
    With ECC is mounted on the bottom of the blower motor and looks like this
    Without ECC is mounted on the blower motor housing next to heater matrix and looks like this
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 151000
    people on here will need to know if you have climate or standard air con ie just 4 settings or 7 settings
  1. Heaters/Blowers Only Working on No. 5
    By Madison5 in forum Electrical & ICE (including SatNav)
    Last Post: 14th February 2013, 00:47
  2. Blowers not working on number 1
    By tubby in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2012, 12:19
  3. Blowers not working on position 4.
    By Slammedorion in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2012, 18:01
  4. Blowers not working
    By DJM in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2012, 19:06
  5. Heater Blowers
    By 3.2_V6_VXR in forum Bodywork & Interior
    Last Post: 24th September 2006, 19:00
vauxhall signum 03 2.2dti blowers dont work
vectra 3.2 heater fuse
signum 2.2 dti blowers not working
