Results 1 to 10 of 15
Thread: Possible top strut mount gone
    Mar 2013
    norwich norfolk
    Vehicle : signum
    Trim : exclusive
    Engine : 1.9 cdti 150
    Default Possible top strut mount gone
    Hi have got a signum 1.9 cdti for the last two weeks my car has sometimes made a springing noise when turning the steering wheel.which I presumed was the top strut mount bearing on the way out.I was planning to replace this at the end of the month(payday).however whilst driving last night the noise got considerably worse.the springing noise has gone and has been replaced by a loud knocking noise.it doesn't do this when in a straight line or going over bumps but more when I turn nearly full lock in when direction it knocks about 3to or 4 times together.this noise appears when moving and when stationary as long as I am steering.its not a cv boot clicking noise.what do u guys think it might be.its coming from the drivers side.thanks
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    I had to replace the top mounts on my old signum it was more a grinding sound when the car was stationary using the steering lock to lock. what you you describing might be a broken spring?
    Mar 2013
    norwich norfolk
    Vehicle : signum
    Trim : exclusive
    Hmm could be the noise does sound like a grinding sort of noise.its really hard to describe.is it dangerous to drive as im not off work until tuesday and the car for work.are the signum suspect struts easy to remove.its a new shape 06.I haven't had a chance to look at it properly yet as was dark but using a torch I couldn't see any breaks on the spring.how do I tell if a mount has gone.if it is the mount can I replace just the bearing or the whole thing thanks for your help
    Trim : vxr
    Mileage : 31000
    If it is the mounts it will be fine but if its a broken spring might not be as safe. the trouble is they are exposed to all the road c..p and be come dry they are plastic my signum was 06 aswell very easy to change I'm sure this is what you need http://www.eurocarparts.com/ecp/c/Va...d74d8d4&000872
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    Similar noise for me - started after leaving it parked for 2 weeks - not if that's related but it had an ominous springy clanging noise when turning and then self centring was pulling one way or the other. Just jacked it up and it's a broken spring on the driver's side. It's broken near the bottom where it gets narrower. Off to consult the Haynes.
    Mar 2013
    norwich norfolk
    Vehicle : signum
    Trim : exclusive
    Thanks for the advice am going to drive it to work today because I work at aftermarket car parts which has a fastfit swell so will get it on a ramp and have a look at the spring
    crook
    That sounds like a broken spring.
    doesnt make no difference coz you have to take strut off to do bearing as well.
    Mine was both
    Jan 2008
    Lincs
    Year : 57
    Mileage : 100k+
    See above. Actually it was broken in 2 places, top and bottom. Replaced the spring but the bearings could do with replacing too I think. Only had time to do one due to the weather, I know it is supposed to be both, but the other will get done next weekend, maybe with bearings both sides too.
    crook
    Quote Originally Posted by vxvirgin View Post
    Make sure you change spring on other side.
    Common fault to go at top and bottom
    Mar 2013
    norwich norfolk
    Vehicle : signum
    Trim : exclusive
    I couldn't get it on the ramp today but jacked it up while my girlfriend turned the steering wheel.the spring looks complete and in good condition. The spring turns freely and doesn't kick back.however the grinflding noise seems to be coming from the strut mount as if u put your ear near it I can hear thats where its coming from.so does that mean its the bearing thats gone and is it dangerous to drive until tuesday.thanks for all your replys and is there any special tools I need to remove the strut other than spring clamps
  1. Strut mount top plate
    By baluachrach in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2012, 00:10
  2. Strut top mount bolts...
    By DNS in forum Suspension, Wheels & Brakes
    Last Post: 29th February 2012, 21:51
  3. Strut top mount noise.
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2011, 14:21
  4. Strut Top Mount
    By PORKBALLS29 in forum Suspension, Wheels & Brakes
    Last Post: 22nd November 2010, 22:19
vectra c top top strut mount wear
vectra strut mount
vectra c top mount worn
vectra cdti strut bearing
upper strut mount replacement vectra c
vauxhall vectra c top mount
strut top mount removal vectra c
strut top mounts vectra c what others fit
