Thread: slow pulling away
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Engine : 1.9 cdti 150
    Mileage : 119k
    Default slow pulling away
    Still experiencing slow pull away from standstill. Then once at 2000k revs the car flies.
    Its a 150 auto with 90k miles. Mas remap with egr and dpf removal. Silicon vaccum pipes, boost sensor cleaned, EGR now unplugged.
    Anyone any suggestions I can try?
    Mar 2012
    wakefield
    Vehicle : vectra v6 cdti
    Trim : sri
    Mileage : 70000
    Is it at 2000 rpm that the turbo begins to spool or can you ear it trying earlier.
    Regular Member beat275's Avatar
    Aug 2011
    Newcastle West Denton
    Vehicle : Hatch
    Trim : SRI
    Engine : 2.0T
    Mileage : 90000
    Either disconnect the battery for half an hour or check for boost pipe split
    Feb 2013
    A Higher Level
    Vehicle : VECTRA C
    Trim : YES
    Engine : 1.9 CDTI
    Speak with paulvectrac, he is the approved remapper on here.
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Ive got a mas performance remap in the car. But the slow pull away was there before the remap and is still there after the remap.
    Does a degraded maf sensor cause the engine warning light to come on? I know a dodgy maf on my last car caused a similar symptom.
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    276 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Quote Originally Posted by chrislloydie View Post
    Only if it is so far gone that the measured values are implausible when compared to MAP sensor, VE map etc. The thresholds are quite generous, so you will get performance degradation long before any fault codes appear.
    If you were to get me an opcom data log during a full throttle accelleration from idle to at least 2500rpm, I should be able to do som calculations and work out if that is the cause of your problem, or might even spot another anomaly.
    Sep 2010
    Milton Keynes
    Vehicle : vectra
    Trim : sri auto
    Mileage : 119k
    Ok thanks. Just need to find someone local with opcom.
  1. Pulling to the right.
    By sriandy in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2012, 23:41
  2. Slow to pull away - dangerously slow to pull away (150cdti auto)
    By the1theycallthe1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 21:10
  3. Car pulling to the right :(
    By !tf in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2011, 19:18
  4. Pulling All Over? please help
    By stubby1988 in forum Suspension, Wheels & Brakes
    Last Post: 25th May 2010, 13:05
  5. Pulling Out Of The Pod...
    By Mark The Cabby in forum General Chat
    Last Post: 6th June 2006, 23:14
vauxhall vectra cdti auto is slow when pulling away
vectra pulling away very slow
