Results 1 to 10 of 13
Thread: Car Wont Start after cleaning EGR
    Regular Member leedrummond's Avatar
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Engine : 1.9 CDTI 8v
    Mileage : 150,000
    confused Car Wont Start after cleaning EGR
    Over the past 2-3 weeks my cars been running a bit strange (lack of power)
    i had previously cleaned egr valve and this solved that issue, which made me think its this again..
    However over the past 2-3 days my car was struggling to keep the revs up when i came to the car each day. gradually after about 30 seconds it would idle correctly. (started to sound like it was running on 2 cylinders
    Anyway, today i thought right i will clean EGR valve as it must be this causing me problems. took off the EGR valve cleaned it, reassembled, then my car would try to start but would idle propperly then after 5 seconds cut out.
    After trying around 5 times, it now wont even fire up
    I have tried widdling the EGR connector incase its that
    What else is there i can check.
    There is diesel in the car, not mixed it with petrol, did add some addative about 4 days ago to try and cure the problem if it was injectors.
    All help really appreciated.
    Kind Regards
    Lee
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    5 Post(s)
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    is the spanner light on?
    Hanging Heaton
    35 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 140k
    Usually after I've stripped and cleaned stuff they do usually struggle, plus then fire all the crap out, I'd keep trying mate personally if its just 5 times...
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    Hi thanks for the replys. Yes the spanner icon is lit in the centre
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    Just been out again to keep trying but dash lights are now dimming so think my battery is drainimg after the tries
    Aug 2011
    Basingstoke
    5 Post(s)
    Trim : SRI
    you did plug it back in properly??
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds like the EGR may be stuck open. This will cause poor starting. Try a good long crank (about 30 seconds MAX), if it starts, give it a run. If not, I'd strip it again and double check everything.
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    Will check this again first thing in the morning. The electrical connector was plugged in ok. I also took off the part mext to it to clean. With large butterfly switch inside. The part inside was in the open positiom when I cleaned it. Could ot be that perhaps stuck open?
    The actual egr spring when I split the egr up I troed to press it but woildnt operate but wasnt sure of it would or not if it requires the solenoid to do this and its impossible to operate manually???
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    First of all, what engine is this and what car is this?
    Milage and previous work done please?
    Apr 2011
    Stoke On Trent
    Trim : 120 Exclusiv
    Mileage : 150,000
    2007 Vectra 1.9cdti 120 150k mileage previous jcb managers car. Well serviced every 6 months via jcb.
    Should I be able press the little pin by hand when I split the egr valve from the plastic solenoid side do you know
  1. Wont Start!!
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 5th August 2012, 19:15
  2. 2.2 cut out now wont start
    By spink1972 in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 08:32
  3. 2.2 dti wont start
    By Tayla in forum Engine & Drivetrain
    Last Post: 3rd February 2011, 21:09
  4. car wont start!! help!!
    Last Post: 20th January 2011, 15:39
  5. help car wont start!!
    By vectragsi3.2 in forum Engine & Drivetrain
    Last Post: 11th December 2010, 03:51
vauxhall 1.9 cdti cleaned egr now wont start
egr valve renault trafic
meriva not starting after egr clean
vectra c will not start after egr cleaning
1.9 cdti 8v wont start
egr cleaning Astra h wont start
can egr cause starting problems on cdti 120
car wont start after cleaning egr valve
egr valve causing starting problems 1.9 cdti
1.9 cdti wont start egr
vectra 1.9 cdti egr wont start
vauxhall vivaro wont start after cleaning egr valve
renault trafic wont start after cleaning egr valve
saab 2.2 egr wont start
2008 vauxhall vectra 1.9 cdti 150 wont start egr www.vectra-c.com
car egr
after cleaning egr saab
vauxhall vectra does not start after engine wash
why deos my car nor start after i cleaned egr valve
wont start after egr cleaning
