Thread: Phono outputs on cd70 navi
    Regular Member rickisgrate's Avatar
    Jan 2012
    Ayrshire
    Default Phono outputs on cd70 navi
    Ive been searching for ages but cant find a real definitive answer. Ive gotta cd70 navi and was just wondering if i can hook an amp up to run some rear speakers. Ive still got 2 alpine amps in my bedroom which could be some use if they can hook up to the factory H/U. If not ill have to sell em
    scottish region
    Yeah u can hook an amp up to cd70 will find a thread on it
    Jan 2012
    Ayrshire
    Ive searched but no joy
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    You'll need a line output converter. You wire it into the speaker wires on the quadlock plug and an earth, and it gives you your pre-out connectors for the RCA cables to your amplifiers.
    Autoleads part number is PC1-601, it's 2 channel so if you want to do one for front and one for rear, you'll need two of them.
    Depending on the amps you have, you might also find they have a high-level input, in which case you simply chop (or tap into, if you're just fitting a sub for example) the speaker wires from the quadlock, extend them to your amp and connect them to the high-level inputs.
  1. cd70 navi
    By vectra sri dan in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2011, 14:47
  2. cd70 navi help
    By aidy-cdti in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2011, 08:16
  3. navi cd70
    By magpie27 in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2009, 22:17
