Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: Vectra C Aftermarket Audio Parts List
  1. #11
    Regular Member ThatAudioBloke's Avatar
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Yes. However this table is for the UK market so all I can do is assume that foreign-registered cars will work, I can't promise it.
    You are better off contacting a car audio dealer in your local territory in case of any problems. There are also foreign dealers of different kit (again for different markets) which are not covered by this table.
  2. #12
    Dec 2013
    dundee
    Vehicle : vectra
    Trim : sri
    Engine : 1.8vvt
    Prob being thick but what does BC stand for?
    Does anyone know if the adaptor for steering wheel controls is the same as a mk4 astra?
    Was goin to give mines away but ill keep it if I can use it in the vectra
  3. #13
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    BC = Board Computer.
    The Mk4 Astra stalk control might be compatible with a half-CAN vectra, however any vectra after around 2005 will need a different adaptor.
    Autoleads list PC99-X06 for both the Astra mk4 and the Vectra up to 2004, however I'm not 100% sure that is actually correct.
  4. #14
    Jan 2008
    117 Post(s)
    Vehicle : .....
    Trim : .....
    Engine : .....
    Year : .....
    Mileage : .......
    Quote Originally Posted by vxkell View Post
    bc - board computer
    as far as im aware, the astra one may fit if yours is half can
    preface vec - half canbus, facelift vec - full canbus.
  5. #15
    Dec 2013
    dundee
    Vehicle : vectra
    Trim : sri
    Engine : 1.8vvt
    Mines is a facelift so looks like its no good
  6. #16
    Jul 2012
    Devon
    Which wires in the block connector are responsible for steering wheel controls in a half-canbus vectra c. Also are they of the variable resistant type?.
  7. #17
    Regular Member bigd123's Avatar
    Oct 2013
    pontefract
    Vehicle : vectra
    Trim : Sri
    Engine : 2.2 dti
    Not sure if daft question or not but is there a difference between the autoleads and connect2 do i need to order specific or can i just get one
  8. #18
    Feb 2013
    Newcastle, UK
    20 Post(s)
    Engine : CDTI 150
    Mileage : 103000
    Quote Originally Posted by bigd123 View Post
    They're different companies, so if you get a connects2 harness, you'll need a connects2 patch.
    Also, in terms of the harness adaptors - connects2 seem to generally be better than the Autoleads equivalent.
  9. #19
    Oct 2013
    pontefract
    Vehicle : vectra
    Trim : Sri
    Engine : 2.2 dti
    ah cool ok ill go with connect2 then so ill be wanting ctsvx001 + patch as i want to keep my controls
  10. #20
    Apr 2014
    Bridgnorth
    Trim : Breeze
    Engine : 1.9 150
    silly qusetion but does that mean if i replace the standard cd30 unit with a pioneer double din and use this iso and patch i could still access and use the trip computer ( mpg, range ect) ?
    http://www.ebay.co.uk/itm/PC99-X80-P...item2ed21be372
    many thanks
  1. help with parts list
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 22nd June 2009, 10:09
  2. Big list of parts !!
    By poves in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 16th December 2008, 17:43
  3. Aftermarket mod parts ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2007, 16:26
  4. Wiring harness And FAKRA for aftermarket audio
    By Darrell in forum Parts for sale
    Last Post: 6th July 2007, 23:23
vectra c aftermarket parts
vectra c swc
why is there no aftermarket parts for vectra
