Where is the deul pump fuse on a vectra o4 3.2 gsi ? .....
Good question Dan. I assume it varies depending on who fitted the conversion.
On my car however, there are a couple of fuses fitted both on the outside, and also the inside, of the battery box.
There is also an extra fuse in a seperate inline fuseholder lying in the spare space at the front of the engine fusebox to the right of the battery.
However, which of these is which, I'm not sure, simply that they are not a Vx dealer fitted option.
Woody
No 10 20amp. Situated in the boot area.
So, a dual fuel pump, not fitted by Vx and on LPG, is that fuse in the boot Ed ?
Glad you got it sorted fella. Oh well, another shining example of learning on the forum as you go along![]()
